There is video on Youtube on the door panel removal on a Toyota Matrix. While you have the door panels removed you have an opportunity to deaden the sound on the door skins with Peel and Seal roofing membrane (Lowe's, Home Depot). It will improve the clarity of the sound.Sonders wrote:Thanks Vibebear for clearing that up. I've never been big into audio and definitely do not fully understand the whole 2,4,8 ohm. Looks like I need to order some Metra wiring harness adapters for the speakers and I'll have me a weekend project. Already read through the post on door panel removal a few times so should be ready to go. Only hang up I'm thinking I'll have will be getting the Alpine 1" tweeters fit into the sail panels in place of the oem tweeters properly.
Maybe later on I'll look further into the amp bypass for more power to the speakers from my Headunit. For now I need to get some speakers in place of the non functioning speaker in the drivers door.
Any other tips for this install would be greatly appreciated.
I have read that the door woofer and tweeter leads are both full range, the OEM tweeter used an inline filter to cut the lower frequencies. I bypassed the factory lead to the doors and installed an aftermarket crossover, so I am not able to verify.Sonders wrote: About the tweeters? Do they get connected to factory wiring for the oem tweeters, or will I still run my crossovers and wiring to the nee tweeters instead? The levels are being filtered at the amp already before going to the separate speakers right?
