Hello All,
Iam pulling my hair out over this issue. My daughters 2009 1.8l vibe keeps throwing p0171 codes. It got worse over the past cold weeks in the mountains of NC. I have replaced the intake manifold and throttle gaskes with no luck. The car will ide ok, but usung the odb2 reader I notice that the air fule ration sometimes will creep up to 17.5 air to fule and the idle roughens a bit. As expected. I have searched for the usual vacume leaks and I have not found any. I have spraded a bit fo carb cleaner around the various sea, hoses and clamps and nothing really happenend. One odd thing I did notice is that if I pull up on the bottom of the intake manfold the air fule ratio slowly moved to lean nd if I pushed down the readings richened up. OK, so I might have a clue. I next lostened the bolt on the bottom of the intake manifold and then retightend it and the readings held.
I like good news but I am afraid that the issue will just show up again.
Does any one have a better suggestion on what is going on? Do I need a new intake manifold? have people been having problems with them?
I appreciate any help I can get and will share the solution once it is discovered.
