The bottom is tapered, and seems to fit the steel wheel fine. Everything is mounted up, I just want to make sure these are ok to use on the steel wheels.
No I would not use the steel wheel lug nuts on the factory alloy wheels. I don't think they will fit the wheels and they will not secure them properly. The alloy wheels are designed to use the mag style shaft lug nuts that secure the wheel with a washer. The washer in the lug nuts above is what holds the wheel in place, not the tapered part of the lug nuts like on steel wheels. On my picture (the first on in this thread) you can see that the end is not worn down or shiny, since it does not contact anything on the car.Sonders wrote:If this is thread jacking let me know and I can start a new thread. Will the lugnuts that come on the steel wheels fit the 16" alloy wheels? The overall diameter of the lugnuts with the outside threads for hubcaps makes them larger, atleast they appear to be. Didn't know if they would fit in the openings on the alloy wheels.
