Yes, you probably found and fixed the issue.
This is how I understand it: The engine aspirates air and the amount of air depends on the rpm and throttle position. Let's neglect a few other influences. This air travels from the intake snorkel near the front of the car, through the air cleaner, the MAF sensor, the intake manifold into the cylinder that is open. The MAF sensor is near the air cleaner, so any air that enters past it will not be measured and it will actually reduce the airflow through the MAF sensor. The computer thinks there is little air and thus injects little fuel. Sometimes too little to get it ignited. You had no-start condition because of fuel starvation. Sometimes the lid was tight enough to get it going.
I might add: when the engine is cold the computer does not use the data from the sensors but but data from the program. Still, the vacuum leak caused the lean condition that kept it from starting.
All that has nothing to do with the power steering.
When you tightened the intake manifold you fixed the airflow through the MAF sensor. The PCM gets the proper data and figures the proper amount of fuel.
Or, when the engine is cold: the airflow is back in its range so the computer program figures the proper amount of fuel.
It really doesn't explain the starting issues unless the car freaks out when it detects a bad A/F ratio when attempting to crank.
At this point the computer is not in the detection business. It uses the data to calculate the amount of fuel to inject. Once the engine is warmed up then the computer is using data from the Heated O2 sensors to detect irregularities.
If you had taken this car to a less than ethical mechanic he could have told you you need: 4 spark plugs, ignition coils, MAF sensor, and PCM for a fantastic total of only $2000.00............Pad yourself on the left shoulder
