I own a 2006 Pontiac Vibe. A few months ago I parked my Vibe too close to the curb. When my passenger opened the front passenger door to get into the car, he lodged the bottom corner of the door into a grassed embankment. After he sat down, his additional weight caused the corner of the door to get stuck in the grass, which prevented him from closing the door in the normal manner. To dislodge the door, he gave the door handle a firm tug, which dislodged the door from grass, but also dislodged part of the bottom plastic molding from the door. Three of the molding clips are no longer holding the molding onto the door. I think that I can re-mount the molding into the clips, but I need to first entirely remove the molding from the door. It appears that the clips are slotted, so I’m guessing that the molding can be popped off at the leading edge, and then slid backwards toward its trailing edge to remove it. But since I cannot find a diagram of how the molding is attached to the door, I cannot be certain if my hypothesis is correct, and I do not want to damage the molding any further when I remove it from the door. It also appears that the molding may also have an adhesive to help hold it in place.
Are there any members who can describe how best to remove the molding, and then re-install it from the door?
