Speed gauge wire for nav system
kumquat
Post by kumquat »
I'm installing a JVC KW-NT300 navigation system. Looks like I can bypass the parking brake by just grounding the appropriate wire, which is great. But I need to hook it up to a speed sensor wire as well.
What wire should I use for this?
kumquat
Re: Speed gauge wire for nav system
Post by kumquat »
The service manual lists pin 35 and 36 on the instrument panel connector both as "vehicle speed sensor signal." One is VT (violet?) and the other is "L-GN" (light green?)
Which should I use?
kumquat
Post by kumquat »
For anyone else curious, I used the violet wire and it's working fine.
