Dash Lights Flash with Turn Signal
Hello,
I have an 07 Vibe. This morning my lights started acting funky. When I have the dash lights dimmed and DRLs on, the dash lights flash with the turn signals or hazard lights. If I turn the dimmer all the way up, no issue. When I turn on the headlights (using the switch) the dash lights do not flash with the turn signals, regardless if they are dimmed or not.
Does anyone know why this may be? I haven't seen anything about others have a similar issue.
Thanks for the help,
Zack
Derf
Re: Dash Lights Flash with Turn Signal
Post by Derf »
Rubbed wires that are touching, possibly due to rodents... I would check to see if you have had any visitors in your car, tell tale signs of mice.
Alternatively the Vibe lights are ground (-) controlled. If the rheostat in the dash dimmer is on the way out, could cause a floating ground where the turn signal power surge is strong enough to cause the dash lights to brighten up. Cleaning/inspecting/working the dash dimmer may clear up part of or most of your issue.
2005 #10,524 Neptune Vibe "Bandit" Auto, Moon & Tunes 238k :D
1991 Pontiac Bonneville 3.8L "Granny's Whip" 142k (33nd Anniversary :o )
beemerphile1
Post by beemerphile1 »
Lights that behave in the manner described usually have an inadequate ground connection. Unfortunately I can't suggest where you start looking.
Any work or modifications been done recently? Retrace your steps.
Per a different thread I started with other details regarding this- finally got a chance to check it out and see what the issue was. I pulled the bulbs out and turned on the lights to see what was going on. A few LEDs were out on the one bulb, no idea why either. Anyhow, stuck a regular bulb in, and tada. It was fixed. I'm guessing the LEDs being out were causing it to draw even less amperage (sorry if this isn't the right term) and caused feedback in it and made the lights pulse.
Anyhow, the issue is resolved. Time to invest in a TapTurn flasher! I can't wait for that.
Thanks everyone.
