Hello and thank you to the genvibe community.  I had the check engine light on, which gave a code of P0420, the powertrain catalyst system.  I have a 2003 vibe, and was hoping I didn't need a new catalytic converter.
So I read some posts on genvibe and decided to follow the advice of fixing inexpensive things first. I replaced the air filter and spark plugs to no effect (but mpg improved).  So I changed both oxygen sensors, and that did the trick.  So thank you genvibers, you saved me from having to buy a very expensive catalytic converter......
