Was wondering if anyone has any sort of details on the factory amp for the moon and tunes package even a model # would be helpful.
I am installing a new deck tomorrow and am wondering if the factory amp is 200Watts RMS or 200Watts Max... given its physical size it could quite easily be 50Watt RMS per channel(assuming there is only 4 channels not 6).
Also according to the wiring diagram the harness has separate wires for tweeters and door speakers but several people have said that they are inline... anyone know the truth?
The New speakers I am installing have a passive crossover and I am going to install these under the seat and just cut the tweeter output wires from the factory harness as well as the front speaker output wires... then connect the wire from the factory amp to the crossover then the crossover out to the cut wires... should all work fairly well as when looking at the factory tweeters their crossover is "built in" to them.
When I do this install I will install just the Head Unit first and take many photos for a write up as there seems to be much confusion into how to install a new head unit using the factory amp/speakers without having to buy the $40-60 line level converter.
Depending on my findings about whether the factory amp is 50Watt RMS I am also going to install a second amp for front speakers and then power the rears from the factory unit as I have to assume a external 50Wattx4 peak is better than the one built into a head unit given the space(head unit is 50watt peak and 17watts rms) :p.
