When it sits for four hours or so it will make the most terrible noise when I go to start it. I swear it sounds like a piston smacking into a valve or something. Today it did it so bad the engine almost stalled. It seems to be the same issue described in these threads:
viewtopic.php?t=38242" onclick="window.open(this.href);return false;
viewtopic.php?f=12&t=40263" onclick="window.open(this.href);return false;
But I'm not sure. If I take the valve cover off, will there be a way to tell if this is indeed the issue? Missing teeth on the cam shaft gear or something?
