Hello all. Thanks for the help on the wipers insert question. I finally got them, and did the job. What a difference! In this case it was very quick & easy. I'm definitely not a person who knows his way around working on cars, but I do try to tackle jobs that I can read-up on, perhaps watch a how to video, and then get a job done. It's a great feeling once you learn how to do something & complete the job. Unfortunately, like most of us, the difficulty is finding the time to do a job and weighing that out against simply paying a mechanic. Ugh.
Anyway, my question is about the Transmission fluid. My car is at around 95,000 miles now, and I have never drained or flushed the transmission fluid. Should it be drained? Or should I take it to be flushed?
My Vibe manual says this about the automatic transmission (back at 60,000 miles. D'oh!). I've copied the text from the manual:
"Change automatic transmission fluid every 96 000 km (60,000 miles) if the vehicle is mainly driven under one or more of these conditions:
− In heavy city traffic where the outside temperature regularly reaches 32°C (90°F) or higher.
− In hilly or mountainous terrain.
− When doing frequent trailer towing.
− Uses such as found in taxi, police, or delivery service.
If you do not use your vehicle under any of these conditions, the fluid does not require changing."
These above conditions don't really apply to my driving exactly. I live in New York state, and commute on highways about 45 miles per day.
So...since I'm at 95,000 miles should address the transmission fluid regardless? And again, which is the way to go: drain or flush?
I read some threads on the forum already, but do you have any advice (or can provide links to already established discussions) on the best way to do a transmission drain?
Thanks very much for reading this and for your replies & help!
