New owner of a 2004 Neptune Blue AWD Vibe
oscarjm
Post by oscarjm »
I've been researching this forum for a couple months now while searching for a 1st generation AWD Vibe or Matrix. I finally found one and bought it, so I thought it is time to register and perhaps contribute.
A little background, if you care. I've wanted an AWD Matrix ever since I first saw one, but I was fresh out of grad school and didn't want to take on a loan for a new car. So, I eventually settled for a manual 1996 Honda Civic sedan that has been very reliable, but boring as can be, and have been driving it for the past 8 years without even thinking about selling it. My wife's 2001 RAV4 was traded in for a more family friendly Mazda5 last December, which made my Civic seem really old. So I started looking for an AWD Matrix/Vibe, and realized that the AWD Vibes are more affordable and don't have the extraneous Matrix underbody spoilers and extensions that seem to give the car even less ground clearance.
After a couple months of searching, I finally found a 2004 Neptune Blue AWD Pontiac Vibe that hit most of my criteria: affordable, low miles (68,000+), one owner, accident free, and relatively spotless for its age. ESC, side air bags, and TPMS might have been nice, but would be a rare find and limit me to a later year. I wouldn't have minded the Monsoon sub, either. Here are a couple pics:
Apparently the previous owner was a fan of bumper stickers, and the years hadn't been kind to the paint, so the used car shop repainted everything but the roof (hope this wasn't a missed red flag). They did a great job. A bonus was that it was debadged (but came with all of the emblems if I want to reattach, which I don't) and it has the crossbars on the roof racks. It has a decent aftermarket head unit. I don't know if the speakers have been upgraded, but they sound decent. It is remote start, which will be nice in the winter. On the way home, I got 25 mpg and 27.5 mpg on the highway on cheap tires that were about 5 lbs. under pressure, so hopefully this will improve.
I have a few things I want to do right away:
1- Install mudflaps (already ordered). This car will see some gravel and muddy roads.
2- Fix the recirc actuator (already ordered) so it stops clicking. Thanks to this forum for helping me figure this common issue out.
3- Replace the fluid in the transfer case and rear differential with synthetic. I didn't see any evidence of leaks.
4- Install a trailer hitch for a bike rack and occasional light towing.
5- Purchase a OEM cargo mat and cargo net
A few things I need to think about:
1- Tires- the dealer installed new ProMeter tires. I need to figure out if these are ticking time bombs, and if they are noisier than a name brand tire. I might just put them on Craigslist before unmounting to see if I can get any $ out of them.
2- The steering wheel is not centered. It was supposedly aligned by the dealer, seems to drive relatively straight, so hopefully the alignment shop goofed up. I need to have this checked out and hope I didn't miss some suspension damage when I was looking over the car.
3- How best to tackle the underbody surface rust before it gets out of hand.
4- Whether to install an auxillary transmission cooler. (Already have one just sitting around).
And a few things might be pipe dreams:
1- Install a Pioneer App Radio
2- Install an underseat enclosed sub (looking at Kenwood KSC-SW11- anyone done this?)
3- Window tinting (would really look good with the color of the car)
If I haven't already lost everyone with this long post, does anyone know of a good service manual that covers the AWD components? Chilton's and Haynes don't.
Thanks! Looking forward to hearing from anyone who has some advice or comments about anything above!
vibolista
Re: New owner of a 2004 Neptune Blue AWD Vibe
Post by vibolista »
Shop did a nice job on the paint... looks new! Interior's in good shape, too. With that new paint, a set of mud guards help keep the tar and stone chip wear off the lower areas behind the wheels. Hopefully this car was well taken care of, and if so, should last you a long time.
Tires are important upgrades. There are some very good Low Rolling Resistance tires our there that will help bring your mpg up. Got to TireRack dot com and look up all the appropriate tires that will fit your needs. Don't have a clue where you drive, but if you deal with snow, get a good set of dedicated snow tires and your Vibe will not let you down on the slick stuff. I put a set of Blizzaks on a set of steel wheels for the Winter and even with 2 wheel drive, snow on the road is not an issue.
I went with slightly taller tires on my Vibe for a little extra clearance. You can put a lot of tire in a Vibe wheel well without much problem, as long as your wheels have the proper offset. Your OEM 16 inch alloy wheels are a perfect 39 mm offset... and the OEM steel wheels were also 39 mm offset. There was an available 17 inch OEM alloy that had a 45 mm offset. The Summer 17 inch aftermarket alloy wheels on my Vibe are 38 mm offset, and that places the front tires nearly flush with the edge of the bodywork around the wheel wells. I did install a very quiet tire on the Vibe since road noise is easily heard on this car. Quiet tires help a lot.
Tire pressure is an important mpg factor. I keep my Summer tires at 39 psi front and 37 psi rear. Not too harsh for our roads. Make sure that you read the max inflation printed on your tire... and never inflate above that level. Most modern tires have max cold pressure ratings from 44 to 51 psi.
Go synthetic as soon as you can. Check your air filter and the entire plenum to make sure that it's not full of debris. The engine loves NGK Iridium spark plugs. Most plugs are good for 100,000 miles, but I would check them, just in case. Depending on temperatures where this car was driven, you might want to check or even upgrade the plug wires
I test drove the first 2003 Vibe that showed up in the Portland, Maine area and was instantly sold on it. Size, economy, cargo room and comfort were great. It's definitely a versatile vehicle. The moment my car showed signs of wearing out, I replaced it with the '08 Vibe I currently own. I almost missed out, as the '08 models had just stopped production, so I had to search a bit to get one with the options I wanted. Couldn't find one with the side air bags, but got everything else. Has been trouble free, but it doesn't have too many miles on it yet.
Let us know how that long list you jotted down progresses, and welcome to the Vibe forum!
zythr
Post by zythr »
Hi, Welcome. Another 2004, way to go. :D
Salsa Guy
Post by Salsa Guy »
Get a TRD SC you won't regret the HP.
Anyway I see you are keeping an eye on the Rear Diff and that good. They are fun cars in the snow.
Enjoy!!
Welcome to GenVibe! Thanks for posting pictures of your "new" AWD Vibe right away! It definitely looks to be in great shape and as others said, it looks like the shop did a good job on the paint. Definitely keep us updated on any maintenance and/or modifications you do ;).
Welcome to GenVibe :D Looks clean & love the color. Visit often and enjoy the ride!
w5dmg
Post by w5dmg »
Nice, that looks like mine, same color, wheels, roof rack. Mine is a 2005 and 2wd.
Mine had 66,000 miles on it when purchased, now has 30,000 more.
kc6yot
Post by kc6yot »
That is a good deal for an 04, AWD with the low miles. Nice. The AWD has less horse power due to the way they routed the exhaust, you should also expect only 29 mpg tops, but when it rains and snows the AWD is the way to go. The FWD has more power and better MPG. Very nice looking car. I say hi and welcome. Why can I not find such a deal in Arkansas? All the Vibes here are for sale at dealers are high mark up. Oh well, I will keep looking I will find the next under $4000.00 bargain sooner or later. Love the 03-04 front grill/bumper look over the 05-08. I have three so far and slowly looking for a 4th one.
Nyx8
Post by Nyx8 »
That Vibe does look like new! The front styling on that generation of the vibe is definitely the best IMO :D
~*Nyx*~
2014 Dodge Challenger SXT V6, approx 200 miles
SOLD - 2006 Pontiac Vibe Base 1.8L, 62k miles
SOLD - 1996 Pontiac Firebird V6, 94k miles
SOLD - 2004 Pontiac Sunfire 2.2L, 45k miles
SOLD - 1989 Pontiac Grand Am V6, 100k miles
Derf
Post by Derf »
Nice ride. Keep us updated on your upgrades.
When you add the mudflaps, the screws for the front fender well may seem short, replaced mine with slightly longer stainless screws/washers
808 Vibes
Post by 808 Vibes »
congrats...Neptune is the BEST!
~ ALIS VOLAT PROPRIIS ~
Nice catch, oscarjim!
I have been shopping at Goodwill for a long time, but I never found a Vibe, AWD too. ;)
oscarjm
Post by oscarjm »
oscarjm wrote: I have a few things I want to do right away:
1- Install mudflaps (already ordered). This car will see some gravel and muddy roads. Rear mudflaps installed, cheap universal ones installed in front due to shipping error.
2- Fix the recirc actuator (already ordered) so it stops clicking. Thanks to this forum for helping me figure this common issue out. This wasn’t too bad with a 6mm driver, a small ratchet, and some patience, and I was able to do it without removing the dash. Nice to have fresh air again.
3- Replace the fluid in the transfer case and rear differential with synthetic. I didn’t see any evidence of leaks.
4- Install a trailer hitch for a bike rack and occasional light towing. (Ordering Hidden Hitch 60958 off eBay)
5- Purchase a OEM cargo mat and cargo net. I haven’t yet decided on the need for the cargo mat… I really like being able to sweep out the dirt instead of vacuuming. Found a good deal on NOS Toyota Matrix cargo nets, that included the tie down loops, and I use the nets for securing things I don’t want to roll around. The tie downs have already come in handy in keeping a 7 gallon air compressor in place.
1- Tires- the dealer installed new ProMeter tires. I need to figure out if these are ticking time bombs, and if they are noisier than a name brand tire. I might just put them on Craigslist before unmounting to see if I can get any $ out of them. I’ve decided to keep these on, they seem to perform fine, and I’d rather save some $ for other projects.
2- The steering wheel is not centered. It was supposedly aligned by the dealer, seems to drive relatively straight, so hopefully the alignment shop goofed up. I need to have this checked out and hope I didn’t miss some suspension damage when I was looking over the car.
5- Install a reverse/back up camera. I have a somewhat steep driveway and kids to watch for.
1- Install a Pioneer App Radio (a good argument to complement the reverse camera)
2- Install an underseat enclosed sub (looking at Kenwood KSC-SW11- anyone done this?) Decided against this- not enough clearance under the seat, and the speakers seem to have plenty of power and range, but pop a little at higher volume. They are stock, and I hope to upgrade someday.
If I haven’t already lost everyone with this long post, does anyone know of a good service manual that covers the AWD components? Chilton’s and Hayne’s don’t.
Thanks to everyone who responded! I didn't get the car from Goodwill... that would have been a pretty sweet find if I had though!
I added some updates above in blue.
Almost 1.5 months into owning this car, and I am very happy with it. I had to spend some time fixing up/cleaning my Honda Civic to sell, and it sold fast, and the Vibe feels more like my car since I have license plates on it. I've tested out the AWD on a muddy gravel road and in the rain a couple times, and can't get it to slip, so I'm pretty confident the AWD is working as it should. This car is so practical and versatile- I'm already worried about what I will get next when its time for this car to retire, which hopefully won't be for another 10 years.
The worst gas mileage I've gotten is 19.24 (all city, w/ my wife's lead foot), and the best was around a 250 mile highway trip at 30.5 mpg. I'm averaging 23-24 city and 29 hwy.
One thing I didn't mention above- the drivers side tweeter didn't work, so I pulled the door panel and found that someone had cleanly cut the wire to it (likely the used car dealer). I reattached it and found out why it had been cut- pops and crackles with every bump in the road. I pulled the radio and found that the crossover in the dash had a loose connection which caused crackling issues. I fixed this, but am wondering if the extra crossover is even necessary since the factory tweeters have integrated crossovers.
A couple more radio issues- The speakers have a slight hum when you turn on the key- I think this is the stock amplifier? The speakers sound decent at higher volume, but the hum at lower volumes is annoying. Also, AM reception is nonexistent, and FM is pretty bad. I found the forums about repowering the stock antenna amplifier with an aftermarket stereo, and spliced the red accessory wire from the radio to the black wire on the antenna cable. No improvement whatsoever in reception, and now the radio will stay on when I turn the car off and take out the key. I think a timer eventually turns it off, but I definitely think I crossed the wrong wires. Anyone else have this happen? I might repost in the audio section.
EDIT: I replaced the owered antennae with a junkyard find, as the original was missing the mast. Still no improvement in reception. I lived with having to manually turn off the radio each time I got out of the car until I replaced the front speakers. I removed the jumper wire referenced above, and the radio no longer remained on when the car was off. No idea what happened there, but did find that the GM antennae adapter was loose, so I bent the connection and now have great reception.
oscarjm
Post by oscarjm »
It has been a while since I have posted anything, but I have made a couple minor improvements to my Vibe and thought I would share. I don't post very often, so this is probably going to be comprehensive.
First, I just got it tinted yesterday. Here are some before and after pics. The tinting is 35% in the front, 20% in the rear, and cost $205.
Sorry for the dirty car pictures, but it has been too cold to give it a wash.
A few things:
GAS MILEAGE:
I've put about 14,000 miles on the car since I have bought it, and am generally happy with it, but sometimes get Subaru envy (but try finding a Subaru that is this cheap to purchase and own!). Gas mileage for the past year has averaged 23, which I wish were better, but that is the price I pay for AWD... and many trips include pulling a small boat, loaded trailers, firewood, car-full of weekend vacation gear and kids and a full hitch-hauler, etc.
AWD:
As for the AWD, I've been stranded twice now on the same spot on a rural dirt road in icy conditions. Both times I had to slow down or stop on a hill, and couldn't get started again and ended up abandoning the car. I don't expect the AWD to help me much in ice, but I've never been stranded like that before (and also never took my previous FWD car in conditions like those). I now have a set of emergency tire chains in that narrow storage compartment directly behind the rear seat, just in case.
TIRES:
Also, those cheap ProMeter tires the used car dealer installed felt like hard plastic both times I got stuck and had no grip. I just replaced them with Continental PureContact Ecoplus DWS tires which get great reviews for this car. They are definitely quieter, but I haven't had the chance to test them in ice and snow. We're headed to ski country with it soon, so I should get the chance to see how it does in the snowy mountains.
REPAIRS:
I've had three issues since purchasing the car:
1) I lost all blower fan speeds except for low. After poking around on this forum, I replaced the blower motor resistor (ACDelco 15-80202) and all the fan speeds worked again.
2) The first time I really tested out the AWD offroad on a snowy hill, both inner CV boots cracked on the rear halfshafts. I noticed a green fluid on the snow. I haven't repaired this yet. I'll have to decide whether to replace both halfshafts with remanufactured parts, or try to clean up the joints, regrease, and replace the boots myself. I've replaced front halfshafts before on previous cars, but never the rear. Looks like it will take a weekend.
3) The door check in the driver's side door was rubbing against my window when it was down. Again, from the great info on this site, I removed the door check and used my grinder to grind it down. I'm not sure that anyone else has tried this, but I placed two pennies as a spacer between the door check mount and the door on the inside to angle the door check away from the window. Here is a pic of the ground door check and the pennies, from inside the door:
An alignment fixed my off-center steering wheel.
SOUND SYSTEM:
My stock front speakers sounded great at low volume, but crackled when I turned them up. I replaced them with Polk Audio DB6501 6.5-Inch 2-Way Component System, and also used the Frost King duct insulation on the interior of the front door skin and then another layer to totally enclose the door. Here are some pics from the install:
The speakers sound great, but I didn't have a secure mount for the crossover in each door and the crossovers rattle at higher volumes, which I need to fix. As others have noted, I lost some of the deep bass since the stock amp is 2 ohms and the new speakers are 4 ohms, but the stock rear speakers still have great response and help fill in some of the missing bass. I might use the Frost King duct insulation on the rear doors and other areas of the car as it was cheap and easy to use.
A couple notes about the speaker install- I carefully cut the stock speaker out of its mount to use for the new speaker, as suggested by others, and could not get the door panel to fit back in place. The mounts provided with the Polk speaker ended up fitting great (you have to drill new holes in the door) and provide plenty of clearance when the window is rolled down. I wasted quite a bit of time figuring this out.
When I turned on my stereo to test the speakers, the front speakers didn't work, only the tweeters and rear speakers. After checking all my connections, rewiring the crossovers different ways, it turns out my battery was too drained from having the doors open through the day that it couldn't power up the stock amplifier, or couldn't provide enough power to the front speakers. After the battery charged, I had sound and bass. Who knew?
I still plan to upgrade the stereo and install a reverse camera. Also, my headlight lenses keep yellowing after I use a polishing kit, so I might sand them down and apply UV resistant rattle-can clearcoat to see if I can get them to stay clear. Oh yeah, I also need to take it in for that airbag recall.
So that's it. The car has been great for our family of four, has taken us on many camping trips, trips to the lake, it pulls trailers, can fit a quarter cord of firewood inside (and much more if I wasn't concerned about the weight), and still looks great in 2016.
Feel free to comment on anything or everything!
Nice to see an update from you! It's also great to hear you've done some projects to the Vibe and that it's still treating you well :)!
oscarjm
Post by oscarjm »
Time for a long overdue (3+ years) update on my Vibe. I'm over 130,000 miles now, and still very happy with the car. I'll stick with the order of my previous update:
GAS MILEAGE
I track this with every fill. I average about 23 in the winter, and 27 in the summer, and my driving is probably 50/50 city/highway. On long highway trips, I can hit 30-31. I'm pretty happy with this considering what the Vibe is capable of doing and hauling.
AWD
I haven't gotten stranded or stuck since I put the tire chains in the car... I've never had to use them. The AWD works great, I'm able to drive confidently on muddy, gravel roads, and make it uphill on some muddy paths on some land that we own. No complaints, although I installed mudflaps soon after purchasing the vehicle, and these always drag when I am offroad. More clearance would be great.
TIRES
The Continental PureContact Ecoplus DWS tires lasted a little over 44,000 miles until the tread was less than 2/32 of an inch. I really thought they would last longer, and kept the car aligned. I did fall behind on tire rotation a few times, but the tires wore evenly. After a lot of research, I decided to buy General Altimax RT43 tires based on top reviews in Consumer Reports. I'm hoping they wear a little longer. So far, after almost 3,500 miles, they are quiet and handle well.
REPAIRS
I've done some preventative maintenance, and some required maintenance. I do everything myself.
1)Alternator- Ever since I purchased the car, the battery light was dimly lit at all times. At almost 103,000 miles, the alternator quit, and I installed a new one. I have no idea why, but the battery light as been off ever since the alternator was replaced. I replaced the serpentine belt at the same time.
2) Brakes- new pads and rotors in the front at 104,085. I had a lot of vibration and brake dust, and the pads were starting to get noisy. I kept my old rotors and had them ground at O'reilly auto (free!), and because the vibration returned, I installed the refurbished rotors at 117,000 miles. These have started to vibrate as well, so I likely will have my spare rotors ground and reinstall. Either I'm not bedding the pads properly, or the traffic I drive in to and from work is warping the rotors.
3)A/C Clutch- The A/C went out at around 110,000 miles. After receiving a $1,500 quote from a shop to replace the compressor and evaporator, I did a little trouble shooting and determined that the compressor clutch had gone out. I purchased an OEM A/C Delco compressor clutch ($130 on CARiD) and purchased a compressor clutch puller, and had A/C again.
4) Routine and Preventative Maintenance (besides oil changes/filter changes)
Spark Plugs- replaced at 120,000 miles- NGK iridium.
AWD components- I do have a drip every once and a while from the front transfer case and rear differential. I replace the fluids once a year, and measure the amount that is drained, and the leaks aren't a concern. As I mentioned in my last update, the rear C/V joint axle boots are cracked, but make no noise, so I'm not in a hurry to replace them. If I do, I'll likely replace the rear differential seals at the same time.
Automatic Transmission- at 127,000 miles, I replaced the fluid/filter and gasket (no leaks) with full synthetic valvoline max life multi-vehicle ATF and a Wix filter.
Valve Cover Gasket- at 127,000 miles, I noticed a slight oil leak when changing my oil that looked like it came from the rear of the valve cover. I replaced the gasket and seals and it looks like the problem is fixed.
Intake Gasket- replaced at 127,000 miles based on the problems many folks on this forum have had with leaks. Mine was a FelPro black gasket- and I replaced it with the same. I don't think replacement was necessary, but I did it as a precaution. My engine barely ran after this repair, and by using some starting fluid around the intake, I discovered that a vacuum hose had disconnected from the engine near the air filter.
Springs and Stuts- replaced at 127,000 miles based on some rough handling on potholes and some squeaks and groans. I used Monroe quikstruts for the front, and Moog Springs and Monroe OESpectrum struts on the rears. The rear struts were completely shot. Comparing the OEM KYB rear springs and the MOOG replacements- the MOOG springs are a heavier gauge, have additional windings, but are shorter when uncompressed. However, the ride height is great, and it handles like a new car.
Stereo/Electronics- I installed a Pioneer AVH-280BT receiver along with a reverse camera. The reverse camera is mounted just to the right of the tailgate handle. I installed a Sound Ordnance B-8PTD powered 8" sub under the driver's seat. The sub is great for filling out the lows, and fits well under the seat. I have the level controller for the sub in the little pop down change tray to the left of the steering wheel. The stock speakers in the rear doors still sound great, and I'm still using the stock amp. My only complaint would be that the volume has to be at max when I use the system for calls, which may be attributable to using the stock 2 ohm amp with 4 ohm front speakers. If I had nothing but time on my hands, I would bypass the stock amp as others have done on this forum.
Other issues left to tackle:
1)Sunroof- the passenger side track has started to rattle. I was able to tighten one screw toward the rear using a small bit that I could turn with an open ended wrench. This helped, but there are more screws that are loose, so the headliner will have to come down at some point so I can tighten the rest (and apply some loctite!).
2) Check engine light- comes on intermittently with a p0442 error code for an evap emission leak. I replaced the gas cap, but the light came back on. I can hear the evap solenoid click near the air filter, so I think that is working find. I haven't found a leak, but routinely topped off the tank for years, and likely have damaged the charcoal canister. If this bothers me enough, I'll replace the canister.
3) Exhaust- I had to cut the connection between the muffler and the resonator as I had a bad leak. I replaced this temporarily with a flex tube, but the pipes are different sizes, so I had to build up the resonator pipe with some sheet metal. This worked fine until...
ImageIMG_6036
I was rear-ended in a light mist by a Nissan Versa. Thankfully no one was injured. You can see the extensive damage to her car. As for the Vibe? This is what $2,400 in repairs looks like (it wasn't totaled!). The rear bumper required replacement because the bottom mounting tabs were broken, and they had to paint the new bumper and the tailgate, as well as replace my hitch. Unfortunately, the aftermarket bumper has more of a pebbled look than the OEM one, and I'm not happy about that. In retrospect, I would have searched for a used bumper to have repainted.
ImageIMG_6102
The flexible exhaust pipe was stressed by the accident, and eventually came apart. I have installed another flexible pipe, but will likely look into either replacing the entire exhaust from the manifold back, or cut the pipe between the resonator and catalytic converter and weld in a replacement, along with a new muffler.
I will post a separate thread about why I did all of the preventative maintenance at 127,000 miles, but as a spoiler, it was in preparation for a 3,200 mile road trip pulling a pop up camper!
That should do it- if you've read all of this, thanks!
Nice update; appreciate the info. Glad to see she's still keepin' you moving!
RE your P0442.. I believe this is the purge valve on the charcoal canister causing that code. We have had the same code a few times on our fleet of Vibes, and when replacing that, the issue has resolved. The purge valve collects a lot of grime and tends to stick. You could remove it and clean it up to try to resolve the issues. We opted just to replace. If I find the part number I used, I'll post it here.
Awesome write up! I may opt out for a newer radio soon for my 2004 Vibe GT and if so will do what you did, find a model that includes a back-up camera! I'll definitely be adding front seat heaters before winter as this car will be my primary winter vehicle soon. It will see salt/brine for the first time in its 16 year life :(
oscarjm
Post by oscarjm »
Time for another update. I just posted about a persistent airbag light that wasn't fixed by several clock springs- ended up needing to replace the airbag control module. So, here is what I've done to my car since the last update, in the order of my original post.
Gas Mileage
I'd say 25-26 in mixed driving is usually what I hit. Loaded up with my wife and kids and pulling a 1500-2000# popup camper, I average about 20.
AWD
Still very pleased about how the AWD system works, particularly in loose, rocky terrain.
Tires
I have about 23,000 miles on the General Altimax RT43 tires. I like them so much that we bought a set for my wife's car. They grip well and are quiet and so far the treadwear is excellent.
REPAIRS
1) Starter- went out at 132,000. Almost left me stranded at work. Tip- if your car won't start from a jump start and your battery seems fully charged, get your tire tool out of the back and whack the starter until you can get it to turn over. Install was simple.
2) Brakes- I keep getting vibration on the steering wheel during highway stops. After my last post, I installed new rotors and calipers at 135,000 miles as the old calipers were hanging up. Within a few thousand miles, the vibration was back. I installed new Bosch rotors at 145,576, and the vibration was back after 1,000 miles. I had an independent shop check out the front end, and everything is tight and the wheel bearings are good, and the mechanic thought I should just replace the rotors on my own as they are under warranty. I'll probably just live with this for a while.
3) Rear Wheel Bearings/rear CV axle shafts/rear differential seal- 149,500 miles- I started to notice a whir/low roar that would get louder as I increased speed on the highway. Couldn't quite figure out if it was coming from the front or rear. I discovered that the sound would change somewhat on sharp highway turns, indicating a wheel bearing. I found out it was the rear wheel bearings after jacking up the car and hearing a metallic sound when spinning the rear wheels. Installed Moog wheel bearings (part number 512512) and followed this video https://www.youtube.com/watch?v=q_1pgIOs_Fg and the madstyle1972 repair manual. Since my rear CV boots were torn and leaking, and the differential seal was leaking, I replaced these components as well. I had trouble removing the axle shaft and getting it to clear the wheel bearing knuckle assembly, but luckily I was doing this next to a tree and was able to attach a ratchet strap to the tree and to the top of the knuckle to ratchet it lower to gain some clearance.
The other issue I ran into was the hex plug on the differential. It was stripped. I was able to remove it using a propane torch and a punch and a hammer- using the punch to loosen the hex plug. I replaced this with a new hex plug from the dealer. Make sure you can get this off before replacing the axle shafts! Part numbers for the axle shafts: Cardone 66-5276. Part numbers for the differential seals: National 711097.
I now have a much quieter Vibe and no rear differential leaks!
4) Exhaust- the flex pipe connection I talked about in the earlier post would last about 6 months at a time. It was a pain to replace. As luck would have it, I was unable to avoid a roadkill deer on the highway and had to run over it, which loosened my spring bolt and exhaust donut connection between the manifold and the catalytic converter (the way the car lifted off of the ground, this could have been a lot worse!). I decided it was time for an independent shop to get my business. After I explained that yes, they did make an AWD Vibe/Matrix and yes, the exhaust is totally different even though the parts books don't show this, they welded a pipe in place of the flex pipe, and replaced the exhaust donut. Totally worth $125 to me.
5) Cruise Control- made a separate post about this, but the cruise would cut out on hills. Replaced the control module with a new one- which is specific to the AWD vibe/matrix.
Other issues-
1) Drivers side door check- I replaced the OEM door check with a Dorman replacement, as I was tired of the door swinging open an almost dinging parked cars all of the time. This part was just as bad as the one I replaced. I pulled a door check at the junkyard off of an 08 Prius, and this works just as it should.
2) Check Engine Light- still get the P0442 error code consistently. I can get this code to clear and stay off if temps stay below 50 Fahrenheit, but when the weather warms up the evap system will self check and the light will reappear. When I have some spare time on my hands I will follow zbyers helpful advice and clean up the purge valve.
3) Sunroof track still rattles. I removed the front map light/switch panel and placed a piece of foam (like a portion of a pool noodle) between the roof and the sunroof frame, and this got rid of the rattle in the front, but the rattle in the tracks remains.
4) Oil consumption- I am losing about 1 quart of oil per 7,500 miles per oil change (synthetic oil change schedule). The car doesn't smoke. I have noticed an oil leak near the timing chain tensioner- and I do smell a slight oil burning smell at times at stops. I hope it is that and not the timing cover. I plan to degrease this area and see if I can pinpoint the leak.
So that sums up the issues over the last 20,000+ miles. At 152,000 miles, I don't consider any of these to be major- all issues fixed by affordable parts and repairs I've been able to tackle myself (except for the exhaust- that was money well spent!). I still wouldn't hesitate to tow a camper on a cross country trip with the whole family.
Nice write-up and thanks for sharing. This just goes to show how dependable these cars are and how the simple fixes can keep it rolling down the highway for many more miles to come.
I'm afraid the oil leak is from the dreaded timing gear cover gasket. A royal p.i.t.a. to fix. I'm a huge fan of the r/t 43 tires. If I ever buy another new car, I would not hesitate to rip off the cheap OEM tires and put them on. I've had them on two of my cars and the best thing is that they have proven NOT to be nail magnets.
oscarjm
Post by oscarjm »
Re: the oil leak. It was the timing chain tensioner gasket. I degreased the engine where it was leaking and replaced the o-ring (simple job) and applied some oil resistant RTV to the mating surface as well. I have periodically slid my phone behind the engine to verify that the area around the timing chain tensioner is clean and dry. So far I've been 3,500 miles since the last oil change and the level has not changed on the dipstick, and no more drips on the driveway.
This is a simple, rewarding fix!
oscarjm
Post by oscarjm »
Time for another update: I'm just shy of 172,000 miles.
REPAIRS
1) Front End: I've posted about this elsewhere, but I replaced the front wheel wheel bearings and hubs, inner and outer tie rod ends, driver's side brake hose, resurfaced the front brake rotors and replaced the front brake pads at 157,435 miles. Resulted in a much smoother, quieter ride. However, the left wheel bearing seems to have failed, so I will replace this with a complete hub and spindle assembly.
2) Check Engine Light- P0442 error code. This code would only get thrown when the weather was above 50 degrees. According to a helpful post from zbyers, this indicated a faulty evap canister purge valve. I replaced the valve (located in the undercarriage under the right rear seat on an AWD) and have not had the check engine light come on since.
3) Front Sway Bar Links: had a knocking sound in the front when I would enter my driveway. The sway bar links had some play in them. Replaced at 166,116 miles. (MOOG K80230)
Still have the General Altimax tires on. At 45,000 miles on these tires, there is still plenty of tread left. I am impressed.
oscarjm
Post by oscarjm »
This will unfortunately be my last update. I finally gave in to some pressure from my wife to get a bigger car for our growing kids for more comfortable road trips (and a little more cargo capacity). We were planning to replace her car with a used hybrid Toyota Highlander, but they are hard to find and really expensive right now.
So I thought really hard about what kind of car might be the most Vibe-like, but with more space and towing capacity, and settled on a 2016 Subaru Outback 2.5i Limited. I have had the car for about a month now, and really like it. It gets slightly better gas mileage than the Vibe, has more pep, more room, modern safety features, and is extremely quiet. It also has that swiss army knife capability that the Vibe has.
Here is what I don't like about the Outback in comparison with the Vibe- total lack of nooks and crannies for storage. The Vibe, despite being a compact car, has ample storage space. I really miss the coin slots, the fusebox lid storage compartment, the TRASH BIN!!!, large glovebox, rear side compartments, and all of the storage space under the cargo area. I was able to hide 2 sets of tire chains, a large bungee cord container, tire inflator, a portable jump starter, jumper cables, 2 ball hitches, paper towels, trash bags, duct tape, tow strap, emergency roadside kit, a blanket, etc. in all of those compartments, out of sight. In the outback, I had to reprioritize and stop carrying most of that, and my ball hitch, tire inflator, portable jump starter, and bungee cord container are all out in the open. The Outback engineers really could learn something from the Vibe/Matrix.
I also miss being able to tell people about all of the things my AWD Vibe could do, that people wouldn't expect it to be able to do. Now, the Outback can do everything the Vibe could, but that is expected given its design. I guess what I am saying is, I feel like I'm running with the crowd now, instead of doing something different.
The Vibe sold the same day it was posted, for full asking price. To get it ready for sale, I replaced the left front wheel bearing, had it aligned, and spent the weekend detailing it. It was in great shape, looked great (with the exception of the oxidized clear coat on the roof), and will run well past when the odometer gives up at 300,000. I would have liked to have gotten it to that point, but I am happy with the 104,000 miles I had with it as its second owner. Be well Vibe friends!
