newb! ; What spark plugs do you suggest for 2007 Vibe auto?
pointbob
Post by pointbob »
newb! ; What spark plugs do you all suggest for 2007 Vibe auto (base model)?
THANKS!
Doug14
Re: newb! ; What spark plugs do you suggest for 2007 Vibe au
Post by Doug14 »
NGK iridium or NGK laser iridium(i have these)
pointbob
Post by pointbob »
Doug14 wrote:NGK iridium or NGK laser iridium(i have these)
Would these work?? there so many...is 4589 IFR6T11 correct?
http://www.ebay.com/itm/8-PCS-NGK-Iridi ... 2a&vxp=mtr" onclick="window.open(this.href);return false;
Doug14
Post by Doug14 »
According to the NGK website part numbers, those particular plugs appear to be for the 2ZZ-GE engine (vibe gt) you will need the 1ZZ-FE plugs which are part # IFR5T-11 and stock # 4996 for the laser iriduim plugs or part # BKR5EIX-11 stock # 5464 for the iridium IX plugs. Hope this helps!
Mark
Post by Mark »
No. Use this one: http://shop.advanceautoparts.com/p/ngk- ... spark+plug.
Advance has a $10 rebate when you buy 4 right now.
