Hello fellow Vibers! Im thinking of buying some new wheels for my 2010 base Vibe to replace the steel wheels with hubcaps to jazz it up a bit. Are there any adavantages or disadvantages to switching to a 17 inch wheel vs the OEM 16's? Mileage, ride, etc.......?
You should stick to the original diameter of tire. 225/45/17 is perfect. 17s will handle a bit better because of the lower sidewall. I've got 17 inch Motegi rims with 225/ 45/17 on my '06.
[quote="Raven"]You should stick to the original diameter of tire. 225/45/17 is perfect.
The factory size 16 is what I have now. I figured the 17 would look better but a little concerned what other effects they will have. Mileage, winter performance. etc....
17s will be more expensive to replace and give you a harsher ride due to shorter sidewall.
The only good reason to upsize is for looks and the 'sporty' factor.
@Vibenvy.....I dont know..... they look pretty sweet!! The ride quality does seem to be the only constant complaint about our great little cars tho. I guess at the price level you cant have it all!!
WhgVibe wrote:@Vibenvy.....I dont know..... they look pretty sweet!! The ride quality does seem to be the only constant complaint about our great little cars tho. I guess at the price level you cant have it all!!
No doubt the GT wheels are gorgeous! I like the ride of the GT. It's stiff and sporty, but not too bad. It's kind of funny, I spent a lot of money on aftermarket parts trying to get my former Sunfires to ride like the GT does from the factory !
For some reason I think the Vibe looks great in all wheel diameters 16-18. Post pics when you get 'em!
Ride harshness can be different depending on sidewall construction and of course, air pressure. When I got my 17 inch wheels, I looked for a tire that was rated quiet and comfortable. Tire rack has good bit of info and owner feedback on the tires they sell. They also have a good rating system that you can use to compare tires against one another.
Pirelli has a new all season tire that is a low rolling resistance 17 inch, called the Cinturato P7. Great reviews about how quiet and compliant it is. A great candidate for a Vibe, since anything quiet helps our cars. The compliant part will help give us a better ride, plus it has a high UTQG number (700) that means it should wear well.
Back in 2008, I bought 225/50 17 tires from tirerack.com... Kumho, Ecsta LX Platinum. It has turned out to be a very durable and fairly quiet tire.
I much prefer how my Vibe handles and feels with these 17 inch tires, although they are not great as a snow tire. I have dedicated snows on the OEM 16 inch steel wheels for Winter duty.
Do your homework and find out which tire you would like best.
I went with 17" Motegi Racing MR125's with Cooper Zeon RS3-A's and the car handles noticeably better than the stock 16" on my 2010 base. I use the stock steel rims for dedicated winter snows.
