Hi, i just bought a 2006 Vibe with 93,000 miles form a dealer in Wisc. I will be the second owner.
I noticed that when I press the O/D button on the shifter that the light on the dash does not come
on to show that you disengaged the OD. The dealer said it is always in over drive, which makes sense.
But when I drove other Vibes, the light would go on when I pressed the button on the shifter. Is this
anything to worry about, he said that the light is probably not working. What I don't know is, since I
cannot see a light on the dash, how will I know if it is in over drive or not? Also if I press the button
and nothing happens at all is that a problem, I feel like the button on the shifter does nothing at all
right now. The dealer just down played it, so should I be concerned? I have never had a car that even
had an O/D button to disengage it. Most cars usually are always in OD, any advice would be great, thanks?
crs59@ameritech.net
