Hello folks,
I am working on my mothers 2009 Vibe base 1.8L. She recently had a front passenger blowout which did some heavy damage. I am in the process of the repairs, but have a wiring question.
In the blowout it tore the ABS wire connector off of the vehicle side of the harness. There are two wires coming from it that connect to the abs harness on the hub side. Can anyone advise which color wires go to which? The hub side and vehicle side wiring are different colors from one another, and I can't find anything in the way of a diagram for this system with color codes.
Her ABS light is on as well as the VSC is flashing, so I would assume this wiring issue is to blame. All other damages are cosmetic.
