 Also, the car does seem to vibrate worse when it is warmed up. I am guessing this is because the computer is revving the engine higher until it gets up to operating temp., thus the vibration isn't happening when the engine is cold. The crash that the car was in was enough to dent in the AC radiator in front of the cars radiator, all damage to the body was repaired. I guess the force of the impact could have compromised the engine mounts though? The car was hit from behind and slid into another car in front.
Just my 2 cents, Doesn't sound like motor mounts to me. Dozens of Vibes here with 2-3X that mileage on original motor mounts with no vibration. The frontal crash damage sounds like it was VERY minimal! Consider running the engine cold with the serpentine belt removed for a minute or so to rule out the belt, bent pulleys, damaged tentioner.crashbandit wrote:Hi all, new guy here. I just purchased a 2007 base Vibe with 71000. I have the same vibration issue that a lot of ppl seem to have on here.... My question is, how much damage can I do to the car if I drive it with this problem for a while? Is this something I should be spending money on right away? I would prefer to save up and get some 15" rims and tires to improve my ride quality. The vibration is just annoying right now, but if I am damaging the engine or tranny by driving it like this, then I will go ahead and get an estimate for repairing the engine mounts.....
I only get Chevron, Texaco, Phillips, and Shell gasoline since they add more detergent to the gas. My valves on the intake side are so clean I can hardly believe it when I look at all the oil in the intake manifold from the PCV and breather.vibrologist wrote:The Techron works only on the injectors, valves and combustion chamber.
That means the valves were clean to begin with. There is another reason for the vibration. Hopefully cleaning the MAF sensor helps.crashbandit wrote:I tried the Techron additive and it didn't help at all. My car vibrates if it is in neutral or drive. The only way to get rid of the vibration is to raise the RPMS. Sometimes it's so bad it shakes the steering wheel. I am going to try the MAF and intake cleaner next. Anyone have some good links as to how to properly do this on my engine?
Get throttle body cleaner. There is a special coating on throttle bodys that can be damaged by anything else. The MAF cleaner's main feature is that it cleans well on first contact and then evaporates quickly.crashbandit wrote:I cleaned the MAF sensor, it looked pretty clean already but I went ahead and cleaned it. The car seems to idle at a bit lower RPM now but the vibration is still there. I was wondering if it would be alright to use the MAF cleaner that I bought to clean the throttle body? Just looking to save a few $.
This means there was some stuff in the fuel system, most likely on the injectors. Even though you were using top tier fuels something was affecting fuel system operation. The B-12 Chem tool may also have a cleaning effect on the catalytic converter and the HO2 sensors.Berryman B-12, added to a half full fuel tank this past week (vibration further reduced, but still slightly present)
The new 2AR-FE inline-4 engine has a balance that meshes with the crankshaft and reduces vibration. It idles smooth as butter.crashbandit wrote:I have given up trying to solve this problem. The vibration along with the crappy ride has me looking for a replacement for this car. I think I will be losing my (removed) on this car with the way it runs and rides.
Make sure you get a really long test ride with the car you consider buying. Drive the same roads you are normally driving for a direct comparison. Add a little gas at your own expense. Good luck.crashbandit wrote:I have given up trying to solve this problem. The vibration along with the crappy ride has me looking for a replacement for this car. I think I will be losing my (removed) on this car with the way it runs and rides.
