Hello everyone.
Yesterday I did my first drain and refill on the ATF fluid on a 2007 base model.
I think I may have potentially overfilled the ATF fluid slightly, and was curious if this is going to cause problems/major issues. I have yet to drive the car, so I am unsure if it shifting differently.
Anyways, I basically drained out a little less than 1 gallon of fluid. Almost filled an entire milk jug, and I spilled a bit of it.
I added slightly less than 4 quarts of Toyota Type T-IV ATF fluid. There is about 3 oz left in the last quart.
I tested the fluid levels via the owners manual instructions. All seemed good yesterday with a warm engine. Anyways, today I checked it again with a cold engine and the fluid level is probably about an inch above the hot mark on the dipstick. I guess some of the fluid needed time to settle.
Will this be a problem? Should I drain some out?
So, given that I spilled a tiny amount when adding the fluid, I think I added about 123 or 124 oz (more or less).
Please advise. Thanks.
