07 base vibe, no sunroof, original factory windshield
first owner rarely washed the car and it was garage kept
now it lives outside and I was it regularly
Well was detailing the 07 the other day and noticed the passenger side carpet was soaked. So after a few days of having it pulled back and drying I decided to check everything. A/c drain was connected has the factory zip tie on it and it was clear and working. Then had someone run water outside on the car and im getting a slow leak traveling in behind the firewall insulation pad and pooling in the right front corner of the passenger floorpan.
Going to pull the lower windshield cowl plastic and see if I can see a problem there. I know the HVAC ducting above the cabin filter was stuffed full with leaves when we first got the car so maybe there is more debris somewhere backing water up into the cabin.
Anyone have this problem before? What did you find wrong?
