hey guys I had an idea the other night......
my aem fic has a 12 output that can activate something (usually a shift light) but I don't see any reason I couldn't use it to activate my lift silonoide . after a lot of research if found that the timing is computer controlled and requires a lot of tunning to manipulate. but the lift is an on/off activation
the setup menu has lots of perameters that can be set as to when it would operate such as load and rpm
I know there are minimal gains on a naturaly aspirated application of this but turbocharged 2zz engines like lift at more like 4-5k rpm vs the 6200 stock point
my question is not if this will give me more power but rather will it work at all ?
for instance is it a 5 or 12v system and, do I need to get an extra silonoide to spoof the ecu, can I tap in to it , or do I need to keep the original pluged in and run another wire to a different silonoide
ps im aware I cant spell silonoide but yall know what I mean lol
