Ok, here's what I've done so far:
PKE-003 Passive Keyless Entry system
Four Pin Harness (GRN, PPL) (ORG/GRN not present, last terminal empty)
I started with the
"key sense": spliced the PPL (PKE) wire into the "car" side of the DRK GRN/BLK (car) wire. Next, I spliced the GRN (PKE) wire into the ignition cylinder side of the same DRK GRN/BLK (car) wire. THESE ARE ALL IN THE SMALL CONNECTOR PLUGGED INTO THE IGNITION SWITCH.
Six Pin Harness (BLU, RED, BRN, BRN, YEL, RED)
- BLU=ACC
RED=+12V
BRN=IG2
BRN=IG1
RED=+12V
YEL=START
I need to do: BLU (PKE) into BLU/RED (car)
BRN1 into BLK/WHT
BRN2 into BLK/YEL
RED into ??? (+12V that's always hot)
YEL into RED
THESE ARE ALL IN THE LARGE CONNECTOR IN THE IGNITION SWITCH.
24-Pin Harness
- 1 YEL (large) = OIL CONTROL (not used)
2 BRN = TURN SIGNAL
3 RED = +12V
4 PNK = HORN
5 PPL = TRUNK 1
6 YEL = CENTRAL LOCK WIRE (CLW)
7 WHT/BLK = CLW
8 = YEL/BLK
9 NONE
10 NONE
11 BLU/YEL = NEGATIVE TRIGGER DOOR SWITCH
12 NONE
13 YEL (large) = OIL CTRL (not used)
14 BRN = TURN SIGNAL
15 GRN = TRUNK 3
16 BLU = TRUNK 2
17 BLK = GROUND
18 ORG/BLK = CLW
19 ORG = CLW
20 WHT = CLW
21 NONE
22 BLU/RED = POS TRIGGER DOOR SWITCH
23 ORG/GRN = FOOT BRAKE SIGNAL
24 WHT (large) ACC (input)
I'm ignoring most of those bloody CLWs. I may do 6 YEL into GRN (10 pin harness in KICK PANEL). Ignore 1 YEL and 13 YEL.
2 BRN and 14 BRN into ???
3 RED into ???
4 PNK into GRN/YEL in the HORN SWITCH
5 PPL, 15 GRN, 16 BLU are being ignored for now. They're for a trunk motor.
11 BLU/YEL into BLU/YEL in the KICK PANEL??? (10 pin harness)
17 BLK should be bolted onto a good ground somewhere under the dash and out of harm's way.
22 BLU/RED isn't going to be used on my '06.
23 ORG/GRN into GRN/WHT in the harness above the brake pedal.
24 WHT into ???
I just noticed some mistakes I made via the info you linked me, mate. I was thinking ProDemand would have everything, but it actually left me a looot of empty spots.
