Hello people, I've been looking all through the forums and still have a few questions that I'd like to get a more definitive answer to.
I read that the manual trd ecu will work fine on an auto matrix. I also read that the vibe man/auto ecu is different... my question is, can I use a manual ecu in my auto vibe(base 04 auto)?
Also, what temp is the recommended TRD thermostat? There is a 160 and a 170. The monkey webpage says with the stock ecu, 160 could throw a check engine light for temps too low. Also, the 160 is $80 and the 170 is $30. If the 170 is ok, I'm thinking to just buy the $10 one from the parts store. Stant 1044 or something.
Also, the kit says not to use any sri or cai, will using a k&n sri with the trd ecu work? Will it help at all?
The kit also recommends spark plug upgrades. Denso or ngk plus. Is this necessary and which do you think is better?
Also what are your thoughts on installing motor mount inserts?
Does anyone have a current dose for the 2.3" pulley? I read that it doesn't increase boost, but makes boost faster. It couldn't hurt, could it?
I just bought the setup used and I'm excited and nervous about the project. It doesn't look difficult, but there are 18 pages of instruction! Is there any advice/suggestions for me before I dive into this?
Thank you all for your time and forgive me if some of this information is already scattered throughout the forums.
By the way, this is what I'm thinking.
Base 04 auto stock. Trd supercharger kit with 5th injector and trd ecu + 170° Stant thermostat + k&n sri + recommended ngk plugs. Think it will be ok?
