That's a good idea! Unfortunately, the OEM rotors do not have them.SeattleJeremy wrote:Some disks have threaded holes where a bolts can be inserted and tightened as a way to lift the rotor away from the hub.
Like the smaller holes in this diagram.
http://extranet.soleniuminc.com/Centric ... 044115.jpg" onclick="window.open(this.href);return false;
I've read you can't get too aggressive without damaging wheel bearings, so I avoided smashing it with a big hammer.kumquat wrote:I've generally solved this problem with liberal application of a 5-lb sledge.
Is there a specific location you recommend when striking the rotor? From the side (edge of the rotor)? On the face of the rotor? Between the lugs?kumquat wrote:I haven't busted a wheel bearing yet. Those things handle some pretty serious shocks hitting potholes and stuff. Think about the amount of force applied when the entire weight of a car slams a wheel into a decent-sized pothole. You're going to have a heck of a time generating even that with your arms and a sledge no matter how hard you go at it.
Everywhere. I'd start with a few good whacks around the edges, then a few around the edge near the lug bolts. Then maybe a few from the backside of the rotor surface. I'd go easy on the backside though, that's where you're going to get the most potentially damaging force on the bearing assembly. The rotor floats a little bit around the lugs so you should be able to knock it loose hitting the outer and inner edges.cooter wrote:Is there a specific location you recommend when striking the rotor? From the side (edge of the rotor)? On the face of the rotor? Between the lugs?kumquat wrote:I haven't busted a wheel bearing yet. Those things handle some pretty serious shocks hitting potholes and stuff. Think about the amount of force applied when the entire weight of a car slams a wheel into a decent-sized pothole. You're going to have a heck of a time generating even that with your arms and a sledge no matter how hard you go at it.
Thanks.
That's brilliant!Chiadog wrote:My personal favorite system! youtube video.
https://www.youtube.com/watch?v=mtsTJCRljAs
