Thanks for the imput......................
The extra engine noise can help with hearing shift points as well as freeing up engine bay space (at least in the first gen). I like having ain intake that's so incredibly easy to remove and have out of the way. Then there's the neater appearance...Salsa Guy wrote:Very little gains in HP and MPGs. A K&N drop in will do about the same. If you like a little more noise to make the (removed) dyno think it's faster then yea go for it. $50 VS $250? If it feels good then do it.
Welcome to Genvibe.
That's only if you're moving slowly or holding still. There's actually a lot of airflow going on under there when you're crack-a-lackin' about...which makes my engine bay horrifically dustycptnsolo77 wrote:In my opinion SRI isnt worth the $$$ at all. The engine is still breathing hot air from under the hood.
Welcome to GenVibe! K&N considers their #69-8613TS intake a cold air intake because of the factory intake ducting that comes up from behind the front bumper and into the heat shield that surrounds the air filter. I recently removed the factory intake ducting and resonator though and realized that it definitely should not be considered a cold air intake because the factory ducting basically turns in on itself and isn't really doing anything at all. I'm sure there are probably other intakes that will fit (Scion xB and perhaps Toyota Camry 2.4L), but the one everyone has around here is the K&N #69-8613TS intake. I have plenty of pictures of it installed on both our 2009 Vibe GTs in both our Garages which are linked in my signature below.Dairgo wrote:I'm a bit slow on the uptake. I recently purchased an '09 GT (Metallic Red) and have been surfing around trying to find a definitive answer, but can't...
Is there a CAI kit that fits on the 2.4L engine, and how difficult is it to install?
