what to do about faded rear door emblem?
canadave
Post by canadave »
So the Pontiac arrowhead on the rear of our 2004 Vibe is faded to almost pink. What's the best + cheapest way to handle it? Ideas:
-- replace it (most expensive, unless someone knows where to get one for $10)
-- paint over it (not sure which type of paint to use)
-- plastidip it (next most expensive)
-- decal on top of it (cheap and easy, but would it last/look good? Plus, don't know precisely what colour to get)
Thoughts?
2009 base Vibe, silver"
meidou
Re: what to do about faded rear door emblem?
Post by meidou »
Debadge
canadave
Post by canadave »
meidou wrote:Debadge
Not an option ;) If anything, I'd love to get a new, larger arrowhead badge! It's relatively expensive though :( Trying to save up money for radio upgrade!
Doug14
Post by Doug14 »
I painted the back one on mine using Krylon fusion for plastic, hasn't faded(i also treated mine with a UV protectant) for all the rest i ordered from http://www.grafxwerks.com/shop.php?part=VIBA1
canadave
Post by canadave »
Doug14 wrote:I painted the back one on mine using Krylon fusion for plastic, hasn't faded(i also treated mine with a UV protectant) for all the rest i ordered from http://www.grafxwerks.com/shop.php?part=VIBA1
Interesting...when you painted the back one, did you mask off the thin silver "star" in the middle of the arrowhead emblem, or did you just spray over it entirely?
Doug14
Post by Doug14 »
I masked off the silver star and the edges, it took a few tries to get it right, if you go this route I recommend using 3m blue tape or similar to mask off as the green is too weak. Heres a pic : Image
note* i only painted the rear arrowhead black. The rest of the emblems are overlays from grafxwerks.
canadave
Post by canadave »
Wow. How the heck did you manage to mask off the star? I would think that's pretty hard to do...did you get very tiny scissors to cut the tape that thin? :)
Thanks for the pic btw, looks very nice!
Doug14
Post by Doug14 »
Hahaha, it was a bit of a pain, but I used a combination of scissors and a very thin razor blade. The star in the middle was a few pieces of tape layered then trimmed and pushed to the edges so it was as flush as I could get it, wish you luck!
Derf
Post by Derf »
Went with a decals, many colors, and if you decide down the road to try something different just peel and apply new. Reading posts, the decal lasts 2-5 years depending on how vigorously you wash your Vibe and you local climate.
Link viewtopic.php?f=33&t=40941" onclick="window.open(this.href);return false;
Highly recommend getting the overlay from Grafxwerks. It should have been standard equipment to cover that emblem that faded to pink while the cars were still brand new on the lot. :mrgreen:
Have lots of stuff from them 7+ years old now I think and still looks fantastic.
Kincaid
Post by Kincaid »
Doug14, that is impressively clean.
Doug14
Post by Doug14 »
Kincaid wrote:Doug14, that is impressively clean.
Thankya!
M1MECHANIC
Post by M1MECHANIC »
if you go the paint route, for the star get some grease and apply it just over the star (bearing packing grease works good) that will keep the paint from sticking over the star. used to do this in the military when painting the vehicles much easier than tape and just wipe off around the star and spray paint. let it dry completely and just wipe the grease off and there you go. hope this helps anyone out there.
