Hi All,
I got a P0325 code on by vibe yesterday that read Knock Sensor Fault Bank 1. I have read up a little bit on this and it looks like the first thing to do is check to see that I have 5 volts at the connector. If I do have 5 volts at the connector, I have seen to either do a resistance test across the sensor, or a voltage test on the sensor with a small pin sticking into the connector while it is connected. Anyone have any numbers or a test procedure for this? Also, this happen at 60mph and my normal rpm was about 2700 at this speed. It is pushing 3300 RPm now at 60mph. Does a faulty knock sensor not let the car go into overdrive? Any thoughst and help is appreciated. Thanks
