Is there anything anyone can recommend to soften and smooth out the ride?
Also, as an aside--anyone else frustrated with where to put your right arm if you're a passenger?
Good question! I'm surprised I haven't seen it addressed here yet. I haven't looked into it, but I'd assume someone makes softer sprung struts. Do Corolla's ride as harsh as a Vibe? Anyone?canadave wrote: Is there anything anyone can recommend to soften and smooth out the ride?
Likewise. Pretty squishy sidewalls on those so they softened the ride considerably.Salsa Guy wrote:I have a set of Bridgestone ecopias (sp?). They help my ride out and improved mpgs.
I would have to say there is a caveat to this statement. At what load is the recommended tire PSI? If the recommended PSI is at max load for the vehicle, and the vehicle is operated at less than max load, the PSI can be reduced.vibolista wrote: ...You should never go below the Car Manufacturer's recommended tire pressure....
What brand of strut did you use and where did you get them?LavaIlliniVibe wrote:Tire alignment and new struts improved my ride in my Lava '04 with 144,000+
