Where can i get power in the back seat?
JohnnieMo
Post by JohnnieMo »
I need to add a 12 volt constant power port for my sons headrest tv in the back seat. Short of ripping out everything and testing with the multimeter, can anyone tell me where to find a power feed? I really don't like that the front plug is switched so I want a constant feed.
Thanks
2009 Pontiac Vibe GT
Vulcan05
Re: Where can i get power in the back seat?
Post by Vulcan05 »
I saw the post header and my first thought was, "Candy is dandy, but liquor is quicker." :D
2010 Vibe. Moon roof, Monsoon, 2.4 engine, 5 speed auto, cruise, dark gray.
If you want constant feed you may need to run power. I don't know what in the Vibe takes constant draw. It could be easier to just keep the power switched, and run power from a cigarette outlet up front.
JohnnieMo wrote:I need to add a 12 volt constant power port for my sons headrest tv in the back seat. Short of ripping out everything and testing with the multimeter, can anyone tell me where to find a power feed? I really don't like that the front plug is switched so I want a constant feed.
Thanks
JonnieMo ..... Don't know if this will help but take a look at this photo:
As you can see by my writing on this connector, this is the plug for the factory cig lighter on our 09-10 Vibes! When I installed heated seats I simply spliced into this circuit and it works great. Keep in mind that this circuit is only active with the ignition "on". For me, with heated seats. this worked out great as I wouldn't want the seats heated when the car is off. Anyways this is located under the center console. Simply remove the console and you'll see all this underneath. Solder a new cig lighter assembly to this and you'll now have TWO ports instead of one. Mount it on the back side of the console then junior can plug his stuff in BUT it won't work unless the car is on! Good luck & hope this helps ;)
