2006 Vibe base model 96k miles. I bought it used in 2010 with 68k miles. I don't know about the service history before I got it. I've had zero problems with the car before this.
I had problems with intermittent a/c functioning, so I lurked on the forums and found the advice about replacing the blower motor resistor and/or blower motor. I went ahead and replaced the motor and resistor just to cover all the bases. When I removed the resistor, I noticed the burned out section, so I assume replacing that fixed the original problem. Everything worked fine for about two months.
The motor stopped blowing air once again, it would not work at any speed. The a/c light comes on and I hear the compressor(?) start, but the blower motor does not start. One night, I decided to start checking the fuses. All the fuses were ok. Frustrated, I started pulling and shaking wire bundles under the dash to check for a loose connection. Suddenly, the blower started blowing cold air! I have no idea which bundle of wires did the trick.
This morning, I started the car and turned on the a/c. Once again, nothing. It was working last night when I drove home. This time, playing with the wires had no effect. I double checked the resistor and it's still looking good. I'm no mechanic, but I'm guessing that there is a short somewhere. I have no idea. It will be a while before I can take it to a shop, so I'm hoping there might be some ideas out there for a simple fix or a way to check for the problem.
