Important strut question
dmitri
Post by dmitri »
At the top of the strut theres a 19mm bolt you take out. How do you get this out? My spring is compressed right now and i cant get the 19mm bolt out because when i go to loosen it the shock turns as well.
dmitri
Re: Important strut question (dmitri)
Post by dmitri »
ok i figured it out...i need to go buy an air ratchet for this. I used to have one but it broke, would have made this whole thing so easier. For those who wanted to see where the jack stands go:
dmitri
Post by dmitri »
This is the jack stand on the frame...youll see it, its under the drivers door.
pissedoffgokart
Post by pissedoffgokart »
If you have an allen wrench to fit the strut post and a 19mm wrench, that works as well..
MadBill
Re: Important strut question (pissedoffgokart)
Post by MadBill »
.quote:If you have an allen wrench to fit the strut post and a 19mm wrench, that works as well..The allen socket is just in the rear strut. If dmitri is referring to the front strut, you either need an impact wrench or you can crack it loose while the assembly is still in the car.
dmitri
Re: Important strut question (MadBill)
Post by dmitri »
yea i got an impact wrench and it came right off.
mitro
Post by mitro »
glad to hear it worked out for you. It seems no matter what the car, the impact is the way to go. Alot of the time you need an offset wrench and even then they sometimes wont get in the opening deep enough to get on the nut. That sounded bad. LOL
dmitri
Re: Important strut question (mitro)
Post by dmitri »
lol. Yea my garage is like a mechanics garage. All i need now is a lift, which im probly gonna get because i do alot of work on my camaro and malibu with my dad.
