Best paint to use for interior
wildvibe
Post by wildvibe »
I am gonna paint my interior instead of getting a dash kit whats the best paint for mettalic red to use ? And should I do a clear coatIs it also posible to just buy a plain dash kit from gm and if so how much?
2003 Abyss Vibe GTMoon & Tones PackagePower Package Mods: -Freedom Design Front Strut Bar-Window Tint 20% Sides and Back %35 on Driver and Passenger Door Future Upgrades: -Underdrive Crank Pulley-Borla Catback Exhaust-Injen CAI-ACT Xtreme Clutch Kit w/ 6-Puck Race Disc (Torque Capacity 351 ft.lbs.)-18" Katana - KR-7 (HyperBlack)-Eibach Springs
AKLGT
Re: Best paint to use for interior (wildvibe)
Post by AKLGT »
your best bet is to go to your local paint store and pick out a semi-metallic red you like. have them mix up a spray can and then use that. you will need to use some heavy sealer on the plastic or the paint will react and eat the plastic.
AKLGT1998 Subaru 2.5RS
satur9
Re: Best paint to use for interior (trdvibe)
Post by satur9 »
quote:your best bet is to go to your local paint store and pick out a semi-metallic red you like. have them mix up a spray can and then use that. you will need to use some heavy sealer on the plastic or the paint will react and eat the plastic. i used krylon fusion spray paint its made for plastic so i dont think it will eat it . the clear coat spray paint messed up the color so i had to repaint a piece. it has no sealer on it now just paint do you recomend a good kind of sealer clearcoat or something
AKLGT
Re: Best paint to use for interior (satur9)
Post by AKLGT »
I used the Fusion paint at first. it does ok, but you still have to be careful. if the paint is too fresh it will react with the new paint. make sure you get plenty of coats and dry for min of 1 hr. I haven't found a metallic red that I liked premade in a can. I tried that metal flakes stuff, but it looks pink (as evidenced in my now painted grill).
scherry2
Post by scherry2 »
just the dash parts:L/S trim plate=26.11Radio bezel=38.81Heater Bezel=25.26shift indicator bezel auto trans = 26.32ouch!!
Psychobroker
Re: Best paint to use for interior (scherry2)
Post by Psychobroker »
I am using Testor's Spray Enamels, which are generally used for plastic models. However, they state they will work on plastic, glass, metal, and wood. NOTE: you should allow EACH coat a minimum curing time of 48 hours...I am going for a dark metallic blue. In order to acheive this look, I sprayed two coats of Copper 1251 and am on my 3rd coat of Transparent Blue 1257. After the final coat, I'll apply two or three coats of 1814 Gloss Cote.You can order them at Testor's Site for $3.29/can (only 3 oz.) + s/h and maybe tax OR you can order from UB Hobbies and pay only $2.45/can + $3.90 s/h for up to $20 worth of merchandise. Only sales in WA are taxed.Make sure to **lightly** sand w/ a minimum of 600 grit sandpaper between coats (not gloss)...works well on any imperfections you may find. Make sure to use 3m WetOrDry paper. 400 grit works well to remove the factory crap, but you must use it w/ water or the paper will clog. To speed up the curing process, I leave the panels in a box I made for this project in the cargo space of my vibe. Interior temps will shoot up to 90f+ here in L.A. on a sunny day By Sunday I should be able to apply the first gloss cote layer...I hope to have pics for you guys.I have had a lot of experience with Testor's sprays, but that's the route I'm taking
