clunking noise from driverside
solovibe04
Post by solovibe04 »
I hear this noise when I go over a major bump and when turning sometimes. When just driving down the road and going over normal "rough" roads, I don't hear it. Not wanting to take it to the GM outfit and them tell me they can't find anything wrong. Did the push test on the front end and it didn't bounce at all. Have 129,000k miles on it.
Th17kit
Re: clunking noise from driverside
Post by Th17kit »
Check this, it might be your problem. viewtopic.php?f=26&t=38057
2009 Vibe GT
Manual
K&N Typhoon
MikeReilly
Post by MikeReilly »
You might also want to check the stabilizer assembly (connects the sway bar to the strut). It can clunk if either ball joint goes bad or it's loose.
