So out of nowhere today, the little red dash airbag light came on and won't go off.
It was on solid all the way to work.....when i got there, I cut the engine, then started it up again and the light was off for the 20 seconds I sad there in the parking lot. Thought maybe it was a glitch & went inside. When I left this evening, I had forgotten about the light.....until of course it came on again & stayed on.
I drove about a mile down the road to the gym.....parked....cut the engine, then started it again & the light went out & remained out for the 30 seconds I sat there.....So I went inside to work out.
I came out an hour later, fired up the car and the light was back on....steady. Tried to cut the engine & restart a few times.....but this time the light stayed on each time......Then it stayed on for the 7 mile ride home.
Thinking I could clear the code maybe, I hooked up my OBDII code reader and......nothing, no codes....but the light remained & remains on. It's not throwing any codes at all....which is strange.
I tried to do a 'hard' reset....i.e., disconnect the ground from the battery for a few minutes......Didin't work. Disconnected & reconnected the driver's side seat connectors.....No good.
I haven't and any passengers in the car or fooled with the passenger seat since I bought the car 4 months ago....and the dash indicator for that side seems to be working fine........It's the red dash light that won't go out now.
I did reposition the steering wheel I (up/down...telescoped in/out) last week I think & repositioned my seat last week or the week before.....but other than that, I haven't fooled with anything.
I can accept that maybe there really is a bad sensor or something......BUT why is it not throwing any codes on my OBDII reader? The reader is supposed to be good for both GM & Toyota.
Any ideas? Why no codes? Do you need a special code reader? Mines not cheap...it was a $100 & has worked well with other cars. Are the airbags covered under warranty ( I have a couple months left on the powertrain warranty) . That freakin red light blaring at me is so damn irritating.....especially since I have no idea where to look because I'm not getting any codes. Anytying else I can try? Any help/suggetions would be great....thanks.
