good Vibe-rations
Lucky42
good Vibe-rations
Post by Lucky42 »
hello hello. long time reader, first time poster. bought a 05 2wd base vibe 2 years ago for my wife, been checking in randomly for info since. friends call me lucky; live in southern New England. finally registered because I keep seeing people asking about CAI's for 05-08 base model. I've got THE answer for everyone who wants the red typhoon on their 1zz motor. will take pics of the install and write it up early next week.
Re: good Vibe-rations
Welcome to GenVibe Lucky! Post some pictures of your Vibe in addition to the CAI install pictures ;).
Welcome! Great that you have info on the CAI. My son wants one for his 06 since he really likes how the K&N sounds on my 10 GT. Looking forward to the info. :D
Welcome "Lucky" to GenVibe :D Post pics soon when you get around to it and glad you finally joined us!
2014 Silverado, 2004 Vibe GT
Lucky42
Post by Lucky42 »
Thanks for the interest guys. No time this past weekend to work on the intake; had to do a brake job on it because one of the calipers stuck.
I am not currently employed in an automotive field, but have held ASE certification in the past. After reading many threads about the K&N typhoon on the base model motor, it seems fairly obvious to me where people are running into MIL codes for a lean condition. Capping the PCV hose with a breather negates the purpose of the PCV, or Positive Crankcase Vacuum, hose. The ECM is programmed to a$$ume that the intake is scavenging oil vapor and exhaust valve blowby via the PCV hose to mix with the air/fuel charge. Depending how your valve stem seals are anyone running a breather instead of a pcv could be collecting a considerable amount of oil on the inside of said breather.
Simple solution: get a 5/8" 90 degree silicone elbow ($10 on ebay, or $4 on ebay.au - but extended shipping from china)
then go to your local home store and pick up a 3/4" to 1/2" PEX union. I paid $1.54 for the union at my local depot.
Use the union and elbow to bridge the gap between the valve cover and k&n's pcv hookup like so...
I'm planning on trimming 2" to 3" off one leg of the elbow to make it sit under the valve cover the way the stock hose sits
This obviously won't flow as much as the stock pcv hose, but since some people don't have MIL issues, I believe it will at least make it easier for the ECM to relearn new parameters, reducing the likelihood of MIL issues.
The rest of the instal is as k&n writes it in the instructions.
Will post pics of it installed by tuesday or so; maybe earlier if I get fired over what I did at work today..........
Lucky42
Post by Lucky42 »
oh yeah, if forcing the 3/8" hose onto the 1/2" fitting is a little too difficult, boil some water and dip the hose in it to warm it up so it'll slide right on. the 5/8" elbow is just nicely snug on the 3/4" pex fitting.
Doug14
Post by Doug14 »
Welcome! curious to see how this plays out, the typhoon and the job lol
Lucky42
Post by Lucky42 »
long story short, hostile workplace, no regard for laws and fire codes, so I emailed some photos to the fire Marshall.
Doug14
Post by Doug14 »
Fair enough, I've worked at places like that haha
