Power Steering Reservoir Leak
VibeN4
Post by VibeN4 »
Hi everyone!
This is my first post on this forum. I have an '05 Base Vibe with a leaking power steering reservoir. Apparently, it's not just a matter of replacing the rubber hose connected to the reservoir. The entire assembly must be replaced and it kinda looks complicated. Has anyone replaced this part by him/herself? If so, is it difficult to do? Any advice would be greatly appreciated. Thanks!
cptnsolo77
Re: Power Steering Reservoir Leak
Post by cptnsolo77 »
If the hose is leaking right where it connects to the Reservoir use a really small hose clamp on front of the existing clamp....however DONT OVERTIGHTEN :lol: the reservoir is only plastic. You dont want to crack it. Thats what I did with mine & havent had any issues for years.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Chiadog
Post by Chiadog »
I'm with cptnsolo. Check the hose. The reservoir should not break unless there was an accident or some other incident. You can pick up a cheap replacement at a junk yard, if necessary. Changing it would be easy.
Welcome to the group!
chiadog
VibeN4
Post by VibeN4 »
Chiadog & cptnsolo, replacing the clamp is such a cost-effective way to fix the problem that it didn't even enter my mind. I'll give it a try. Thanks for the advice and thanks for the welcome!
