Thanks Chiadog, I was unaware of fuses in that location...Chiadog wrote:Sounds like a blown fuse. possibly the AM1 fuse under the dash on the drivers side - nasty location for fuses.
You may have to remove each possibly related fuse and test it with a continuity tester as it is too hard to judge a fuses' condition when it is installed in this location. Unless, of course, You're a Proctologist.
chiadog
