Which Pulley set to buy?
Laserbeak43
Post by Laserbeak43 »
Hey,
Looking to buy a pulley set. Only one i've seen so far is
http://www.unorthodoxracing.com/index.p ... -4799.html" onclick="window.open(this.href);return false;
what do you think? there's no description. Any help would be appreciated, Thanks
Salsa Guy
Re: Which Pulley set to buy?
Post by Salsa Guy »
Is it light weight? Underdrive? Overdrive? 7-10 HP gain...doubtfull
Nice pulleys but there will certainly be NO hp gain. Aesthetics only is what you'll gain. They do look impressive though. Also if your Vibe sees winter driving then the salt will destroy these pulleys in no time :x Update your profile showing location for us ;)
2014 Silverado, 2004 Vibe GT
Rayven01
Post by Rayven01 »
:shock: $357 for under-hood aesthetics? Too rich for my blood!
Image  Image
BlueCrush
Post by BlueCrush »
Save some money and get this one instead: http://www.ebay.com/itm/OBX-Power-Pulle ... 32&vxp=mtr" onclick="window.open(this.href);return false;
Same thing as the UR, but a lot less money. I have used these OBX pulley's on my Vibe AWD. No issues.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
revstohigh
Post by revstohigh »
Beware light weigh underdrive pulleys have a tendancy to knock a bit of life off of the engine and can cause leaks at the front seal. I have an unorthadox pulley on my supraand have had no problems, but they are internaly ballanced due to the design of the crank.
03 GT, t3/t40e rear mounted, aem fic,550cc inj, mwr fuel pump, 2 row rad, trd thrmostat, wmr shifter, tokico struts, st springs, progress bars, 17x7 235/45
Salsa Guy
Post by Salsa Guy »
The light weight pulley is more of an issue on the 2zz engine because of it's high revs. The 1zz is far less of an issue unless you bypass the rev limiter.
