A few tips . the install kit comes with plastic strips with little nipples to drill through . the fit very tight so trim them and file out the hole on spoiler a bit .
also very important do not mount the roof spoiler to close to the rack make sure it is set back a bit or you wolnt be able to open the hatch very far ! i learned this the hard way and had to drill 3 new hole an inch back .....
these create a lot of swirl and your rear end will get beyond dirty very quick esp the rear window and on top of the whale tail
