Signatures?
Toasted7
Signatures?
Post by Toasted7 »
Your opinion on signatures... better as text or better as pics?Check out the example for mine (inspired by GEO)
Re: Signatures? (Toasted7)
Cool signit dude.To add it, go to my profile, my signature, then click the "image" blue button right below the text box. two things will show up, the word IMG between brackets, an then the word /IMG between two more brackets. like this:[ IMG ][ /IMG ] (only without the spaces).Between those two middle brackets, insert the URL of the graphic you want to use...but it has to be hosted somewhere, only problem...
Toasted7
Re: Signatures? (ragingfish)
Post by Toasted7 »
Ah... hosting it, that's the problem. Looks like you are just going to have to suffer and CLICK ON IT! haha! So which do you think is better... pics or text?
Actually, since you attached it to the above post, it's now being hosted on GVC...so use this URL to add it to your signit:http://forums.genvibe.com/zerofile/1496/vibelogo.jpgTo answer your question, though, I like the graphic signature, when done right. If it looks good, it makes a nice divider between posts...If it's poorly done though (like my last one), it becomes an eyesore.
Geo
Post by Geo »
I'm quite a big fan of my signature I generally like good-taste signatures as well, images are always great :DText works too, but it is kinda bland
BADGER PRIDE
Toasted7
Post by Toasted7 »
Hey, now it actually works... you can see both the pic and the text version. Thanx ragingfish! (I can always count on someone here to help me out) "Eyesore" or "Nice Divider"?
Re: Signatures? (Geo)
Actually, some people on here can do it with text and it still looks pretty smooth...Can't think of a member offhand but I know I've seen it...
Geo
Post by Geo »
Awesome sig too, Toasted :DWhat font is that? I have to search for it! heehee
BADGER PRIDE
quote:Hey, now it actually works... you can see both the pic and the text version. Thanx ragingfish! (I can always count on someone here to help me out) "Eyesore" or "Nice Divider"? Very nice divider. But pick one and stick with it -- don't keep the text too. That's just overkill.As geo said, what font? I like!
Toasted7
Post by Toasted7 »
the font is called BRADY BUNCH. I thought it went well with the "cutout" filter that I used on the pic of my Vibe in the background... trying not to make it too busy looking, but still able to tell it's a Vibe.
quote:I thought it went well with the "cutout" filter that I used on the pic of my Vibe in the background... Looks like the cartoon filter that I have on one of my graphix programs...
Triton
Post by Triton »
Looks good Toasted7! I am going to do an image like that after I install my springs and repaint my grilles. I won't have any apperance mods other than wheels to do after that. And the wheels are going to be a while.
Re: Signatures?
I've often got a slow connection, so I have my genvibe preferences set up to display signatures, but not images. You're signature shows up for me as a link.
Toasted7
Re: Signatures? (joatmon)
Post by Toasted7 »
I'm on dial-up and it is sloooooowwww... but I have my settings so that it shows everything. On this site it is really worth it - at least I think so.
pissedoffgokart
Post by pissedoffgokart »
Ok, you talked me into creating one....
rasermon
Re: Signatures? (pissedoffgokart)
Post by rasermon »
pissed, toasted, and Geo your sigs. look marvelous.... I need to finish mine.
Robert G
Post by Robert G »
I believe the graphic looks good. I suggest that people try to make them smaller. When everyone has a graphic and are responding to posts, it makes it time consuming to scroll through the posts, seeing the same graphics.
Geo
Re: Signatures? (Robert G)
Post by Geo »
quote:I believe the graphic looks good. I suggest that people try to make them smaller. When everyone has a graphic and are responding to posts, it makes it time consuming to scroll through the posts, seeing the same graphics.So Nick, does this mean we are gonna set a rule for the max size of signature images? I actually use the sig graphics to my advantage for scrolling, I just look for mine and then what's under it is all the new stuff that I need to read Of course, there is an option for sig images being off, isn't there?
BADGER PRIDE
fire_502
Post by fire_502 »
I'm with Robert, the pics in the sigs make the threads really long. On the other hand, they do fill up the space nicely when your post is really short, otherwise you get a huge block with one sentance and it looks barren. Maybe that's why I ramble too much...to fill the space in the smallest block it will give me.
msmyer
Post by msmyer »
I like it! Nice touch!
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
msmyer
Re: Signatures? (msmyer)
Post by msmyer »
How did you make it! Have a step by step? Thanks in advance!
Toasted7
Post by Toasted7 »
I used photoshop, but I'm not sure about everyone else. I took a pic of my Vibe, cropped it down and applied a few filters to it then put the text in a few layers and flattened the image down and presto... you have my signiture. This one was really just to mess around with, but I kinda like it, I think it's a keeper... for now. Photoshop... GOOD! Microsoft Paint...BAD!
I keep the signatures turned off... Sometimes it can take a couple minutes for a thread to load....Dial-up, yeah!!!!
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
cohocarl
Post by cohocarl »
I have my settings so it doesn't automatically include my sig. I'll include it if it's my 1st post to a thread (if I remember), but if I post an additional time to that thread, I won't include it. Less "clutter" I think. One thing I noticed is the members with the animated graphics (which are cool) make my scrolling "stutter" in I.E. I like them, but I'd rather not see them 20 times in one thread.
Toasted7
Re: Signatures? (ColonelPanic)
Post by Toasted7 »
What are you talking about... Dial-up RAWKS! maybe hitting myself in the head three times with the hammer will make my internet connection faster?!?
Geo
Post by Geo »
Step by step?Took background image of Vibe.Copy/pasted different rectangles of it in different layers to give it that weaved look, then used layer effects for the shadows, and glows.Another layer with everything black + layer opacity to make a grey background over the picture of the Vibe with the weave.One layer for all the text in white with a cool font.Another layer for "Geo" and seperate layers for PONTIAC VIBE and Base Automatic used layer effects for bevels and shadows, etc.I then put another small layer with a black rectangle box to serve as a highlight for "Geo" This way when I need to change the image I can move everything around easily, and just redo the "weave" pattern till I find a way to make it all automatic and linked to the background image itself. I didn't use any filters or anything for this signature either, but wait till I "get" Xenoflex and Eyecandy, then I can start doing the cool stuff again lol.
BADGER PRIDE
msmyer
Post by msmyer »
Toasted7-Thanks for mine!
meathead333
Post by meathead333 »
hey i like they new look people are adding. it really spices up the site i think
My myspace.com profile My 73' Bronco Cardomain page
Toasted7
Re: Signatures? (meathead333)
Post by Toasted7 »
I agree meathead333... It adds a lot to the site and makes it look all "nice 'n pretty like!"
Perhaps it's time for me to get one back up there...Hey, who wants to volunteer to make one for me? I'm not so artistic...
scherry2
Post by scherry2 »
well i tried my hand at it. what do ya think??
Toasted7
Re: Signatures? (scherry2)
Post by Toasted7 »
Not bad... not bad at all. I think ya got somethin' there!
msmyer
Post by msmyer »
Nice...It's a keeper!
Toasted7
Post by Toasted7 »
What about this new sig? Which one looks better, my original (seen below) or this new one (click on the link to check it out)??? I'm only asking cause I can't decide.
scherry2
Post by scherry2 »
the new one looks better
msmyer
Post by msmyer »
Hot Vibe
Post by Hot Vibe »
Damn signatures are nice from a newbie's perspective but they are annoying when you are just trying to read the forums. I especially feel sorry for those people who do not have cable access. Those signatures are probably turning away possible members.
Just here to lend a hand to people who have questions about their Vibe.
millster
Re: Signatures? (Hot Vibe)
Post by millster »
Or then there are those of us WITH cable that feels like we're using 56K. Honestly I don't mind the signatures. (I have one too, I just don't use it all the time) I think in some way they add to the posts a bit. It gives some visual interest. The one thing I would mention is watching the file size. Some of them are approaching 70K and that's even hard on my cable modem.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
scherry2
Re: Signatures? (millster)
Post by scherry2 »
oops, sorry.
canadavibegt
Post by canadavibegt »
I run a cable modem and I have no problems with the Pics... Pages load almost instantly everytime...I like the pics.. Some of them are realy well done... Mine is a work in progress as I learn more about Adobe and find inspiration from others.
Canada Rocks View pics of my car here. http://www.cardomain.com/member_pages/v ... _id=345207
millster
Re: Signatures? (canadavibegt)
Post by millster »
Right, well that's most cable modems. For some reason my area doesn't range well and yet they still sell the service. My speed is faster than dial, but just barely.I really like the pictures too and would hate to see them go, but if the upward trend in file size were to continue, they might need to be restricted out of respect for those who can't/don't have high-speed connections.
-Millster-
