Front washer fluid stopped spraying (2009 Vibe)
Sandman
Post by Sandman »
The washer fluid, for the front windshield, stopped working. The rear still works and, yes, the reservoir is full. Any ideas/thoughts?
sideshowalan
Re: Front washer fluid stopped spraying (2009 Vibe)
Post by sideshowalan »
There is a separate pump for the front and rear washers.
Sounds like the front one died.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
gralm
Post by gralm »
sideshowalan wrote:There is a separate pump for the front and rear washers.
Fuse?
When mine froze up, the back still worked while the front was solid... could be that it's frozen in the line (assuming of course that you live in a colder climate and you have summer fluid).
dallairl
Post by dallairl »
having the very same problem... 2003 vibe. Did ALL vibes has seperate pumps (front and back)?
sideshowalan
They all have separate pumps.
The 2 pumps are attached directly to the washer fluid reservoir near the bottom. Each with a line going to the front or back.
2008 Pontiac Vibe
