Hey guys,
I have been looking around for an answer to my question below but I can't find anything that fully fits me: I bought a vibe with 93,000 miles from a girl who appears to have taken very good care of it. She kept up with ALL the required maintenance (coolant change, transmission fluid change, oil change, etc....). I have had it about two weeks and have been noticing that the drive system has some type of issue where if I push down the gas pedal a little bit nothing happens (as in, it doesn't really accelerate like other cars would if pushed in the same amount); if I push it down too quick the car really jolts as it finally "catches", accelerates and subsequently changes gears. After that jolt everything is perfect for the rest of the acceleration curve. As I have looked on the internet, it looks like my 2007 has an electronic throttle cable, so I have no real cable that I can adjust. In older vehicles, I would just tighten the slack in the throttle cable and problem solved. It just feels like something isn't catching between the gas pedal and the transmission. I think the automatic transmission is just fine. The girl was almost crying as she handed me the keys to her car, she just got rid of it because she had to have a truck for her work.
There is no check engine light on.
The ECM was changed under warranty a year or two ago.
1. I tried to do a "reset" procedure I read about where you put your key to the on position, hold down gas pedal 5 seconds, then turn key off - no change in my issue
2. I will take a look at the throttle body this weekend, maybe it's dirty - engine bay is dusty as crap on this car, but I know that the girl I bought it from did change the air filter regularly
My time with working on the car is very limited. I would spend more time diagnosing myself, but I need some suggestions for things to look for this weekend. I have been getting by ok if I just do a very slow, smooth pedal acceleration. But, I don't want to drive the next 10 years with this issue either. If you have any other suggestions on what my problem is, please let me know. I hope I made a good purchase. I finally got to go get back in the saddle of a Japanese vehicle with this baby, after driving an old piece of junk Volvo. Thank you very much in advance!
