I purchased a brand new 2009 Vibe , 1.8, 5-speed manual transmission, in September of 2010. (Yes, based on the build date, the car sat for 16 months on the lot.) When new, the car was VERY easy to stall, in first gear. It grabbed and jerked like no other car I have ever driven. Several others that are familiar with clutches agreed. After two weeks of this, I became frustrated and "rode the clutch" a few times. (I generally keep the RPMs as low as possible, when releasing the clutch.) "Riding" the clutch with high RPMs solved this problem. I assumed the face plate had severe corrosion from sitting 16 months with no use.
The next problem, almost since new, has been the lack of smoothly releasing the clutch in first gear. In other words, the last few inches of the clutch seems to grab and briefly slow the car down. (Gives the sensation that occupants are being thrown forward when shifting to second gear.) The remaining gears are fine. The more weight in the car or the higher the RPM shift, the sensation is significantly reduced or eliminated. The dealer, on several occasions, stated they couldn't find a problem. They convinced me not to worry as the car has a 5/100 power-train warranty that covers drive train issues. (Yeah, right.... the clutch?)
I now have 51,000 miles and the Vibe still "jerks" the last few inches of the clutch in 1st gear. (Yes, I know how to drive a clutch. This is my third manual transmission, in 27 years of driving.) No, the clutch does not slip at all. Also noticed that the first few shifts of the day can result in the clutch shuddering when releasing in 1st gear. I mentally wrote this off as a cold pressure plate and a hydraulic clutch.
Any one else experience these clutch sensations?
Thanks - Doug
