Need new steel wheels
Kelpie
Post by Kelpie »
Hey there,
We have 2 bent rims on our '03 Vibe. Thought we would get a new set of wheels for it, but really just want some stock wheels.
Any suggestions on where to get them? All I can find are fancy aluminum wheels.
Thanks,
Re: Need new steel wheels
Where are you located? I have a full set of steel wheels & hubcaps, but shipping would probably run $20 each. You can probably find some close to home on http://www.car-part.com" onclick="window.open(this.href);return false; Just look in your state or province, type in your zip code, and look for the 16" x 6-1/2" steel wheels if they are the ones with hubcaps. You can probably find some for $30-50 each. Vibe and Matrix wheels will come up. If you want the alloy wheels, then they are a bit more if you can find them.
There are also a few cars being parted out on here. Badvibe has a thread on parts and may have some steel wheels.
Good luck!
Also, if you haven't already, check your local Craig's List. I ended up scoring 3 take off steel wheels (less than 1000 miles on them) from a semi-local guy for $75.00 three years ago through Craig's List.
Kelpie
Post by Kelpie »
Thanks for the info. We are located in Indianapolis.
sagittarius
Post by sagittarius »
Craigs list ... picked up two sets of steels, one three years ago, and one 6 months ago. Blizzak WS60 195/60R16 on each Vibe for the 4 winter months. ;)
2008 Vibe 1.8L base manual
2007 Vibe 1.8L base
1999 F150 XLT 4.6L 4x4
1996 Contour SE 2.5L 5sp Manual
Kincaid
Post by Kincaid »
Last time I needed a factory steel wheel I contacted a local wrecking yard and it was $30.
