light out behind temperature selection knob
leighangela
Post by leighangela »
It looks like there might be two lights behind the three knobs for the vent, heat and temperature knobs. The knob on the right, the one where you choose how cold or warm you want the air to blow, is not lit up at night. The other two knobs are lit up fine. Is there a way to fix this?
leighangela
Re: light out behind temperature selection knob
So googling this, I found one other person with the same problem. He was told he'd have to replace the whole "A/C control head assembly," but I can't find that part anywhere online. Guess I have to ask a dealer :-(
Keylies
Post by Keylies »
Look in the HOWTO section I saw a post on that
KEYLIES 2003 VIBE
It doesn't necessarily involve replacing the whole assembly. I did when I had to replace the bulbs in mine, but that was because I broke it trying to get it out. :twisted:
The bulbs are replaceable on their own, but it is not generally a fun process. Here is a pretty nice writeup:
viewtopic.php?f=28&t=37556&p=420080&#p420080" onclick="window.open(this.href);return false;
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
leighangela
Wow, thank you! Too scary for me.
Flip-Side
Post by Flip-Side »
I had the exact same issue. I pushed the bulbs back in and they began working again. They were not broken, just unseated.
leighangela
Flip-Side wrote:I had the exact same issue. I pushed the bulbs back in and they began working again. They were not broken, just unseated.
But you had to pry off the front right? Was it difficult?
FootScoot
Post by FootScoot »
I'm having the same annoyance. It worked fine 2 days ago, last night was a no show. Looks strange with just 2 working, and the third one dark. Seems there would be an easier way to fix this than removing the radio and all the surrounding stuff just to reseat or replace a small bulb. :roll:
Old slot racer. 2009 Vibe GT owner
