Just installed a new clutch in my 03 GT. I removed the right half shaft so the trans would mate up easier. The right shaft has a carrier bearing on dowels. Does the shaft have to separated where the inner joint couples into the center shaft? Cant seem to get the inner spline to engage into the diff possibly caused by the dowels.
Does the shaft have to be installed in two parts...center solid shaft and then the outer cv shaft? thanks for any help.
