Picked her up on Monday, and thinking of taking it in for an alignment and wheel balancing. Has just a slight pull to the right, and that goes away if I move to the left lane of a 4 lane divided highway! If the Vibe's steering wasn't so tight ya might barely notice this, but it needs just a little pressure to keep her straight. Odd thing is another Vibe I test drove had almost the exact same tiny pull. Is this maybe normal?
Checked pressure and found the right rear at 31 and the other 3 around 27 - evened 'em all to 32.5 psi but a little pull is still there. FYI has 17" wheels on it, FWIW, and fairly decent looking General Altimax HPs on.
If this is not "normal" what do you think it is that would let the car drift in the right lane but not in the left?
Oh, and anything I should pass along to the shop regarding the balance specs (just in case y'all know something about this that the "book" doesn't mention)?
KJ
Oh, noticed a slight vibration when on the freeway, that's why the balance check.
