AirCon seems to be tied to RPM
theMikeD
Post by theMikeD »
I have recently noticed that the A/C doesn't work too well unless the engine is spinning up to about 3k. At lower RPMs it works...barely. Is this a known problem?
...Mike
Re: AirCon seems to be tied to RPM
Aircon is tied to RPMs. The A/C compressor is driven by a belt connected to the crankshaft. Are you sure that it's charged properly?
hotbug1776
Post by hotbug1776 »
Mine is icey at idle. I think you may need a recharge. Or you may have a slipping compressor clutch or loose belt.
djkeev
Post by djkeev »
I agree, check your refrigerant level, if it s low (and it probably is) have them put in a dye charge which will help pinpoint the leak.
Dave
(o ! /o) (o)=I=(o)
