Will an OEM 16" wheel cover fit to a 15" steel wheel?
jeober
Post by jeober »
I thought I read that someone here did this.
I'm interested to use 15" steelies with 195/65R15 mounted from tirerack.
thanks
Re: Will an OEM 16" wheel cover fit to a 15" steel wheel?
They might since they bolt onto the lug nuts and don't clip to the outer rim of the steel wheel like most wheel covers. Do you have the 16" wheel covers and lug nuts? I would just take one along and see if they fit on the steel 15 " wheels without hitting the edge of the rims. I see you are talking about ordering some. Maybe check on some 15" wheels at a salvage yard just to see if they fit?
16" wheel cover on a 15" wheel? I vote no. Once it was bolted down, wouldn't you have the cover seriously overlapping the wheel?
jeober
Post by jeober »
viewtopic.php?f=31&t=29176
aha, I found it.
Has anyone else tried this?
Well that's certainly interesting that it can be done. Good find.
thebarber
Post by thebarber »
please don't.
