Strut bar installed Now a couple of questions.
Celtic_Curse
Post by Celtic_Curse »
Well installed freedom design strut bar..as you all know no instructions, so here are a couple of mine since I don't have a clue.1. is it sapposed to be flat or vertical..once you get the the arms over the struts how is it sapposed to sit?2. do you tighten the hinge bolts? the brass bolts that connect the arm to the bar? how tight would you tighten them?3. is the red arms sapposed to sit perfectly flat against the black factory strut rings?any help would be greatly apprecited folks
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
celica girl
Re: Strut bar installed Now a couple of questions. (Celtic_Curse)
Post by celica girl »
I thought you were gonna wait for me to help you install the bar???
cohocarl
Post by cohocarl »
Check out this thread, it should answer most of your questions.http://forums.genvibe.com/zerothread?id=4746Mine isn't a Fd. bar, but I did tighten down the end bolts that you are talking about. Here's another link with a pic of the fd. bar.:http://forums.genvibe.com/zerothread?id=816
Celtic_Curse
Re: Strut bar installed Now a couple of questions. (cohocarl)
Thank you, Celica Girl you can still help.
Celtic_Curse
Well I guess I had better take the factory ones off, and redo the install...thanks for the advice.
celica girl
Celtic_Curse
Re: Strut bar installed Now a couple of questions. (celica girl)
Thanks for posting Celica girl! So this isthe way we put it in everyone...we took out the factory rings and just slipped on the new FD bar. We were torn between the vertical or horizontal setup but agreed on horizontal. Driving with the setup in both ways I have to stay the horizontal offered the most responce..thanks for everyones help.
Geo
Post by Geo »
quote: Driving with the setup in both ways I have to stay the horizontal offered the most responce..thanks for everyones help. Really now? I might just adjust mine soon, see if it makes even more of a difference :D
BADGER PRIDE
Celtic_Curse
Re: Strut bar installed Now a couple of questions. (Geo)
ya, I know it sound wierd but the vertical had a little affect on the cornering, then when we switched it around there's a better feel and cornering, just my two cents try and let me now if its just in my head.
yank dini
Post by yank dini »
this is how I put mine on
yank dini
Re: Strut bar installed Now a couple of questions. (silverawd26)
Post by yank dini »
now I just need the rear
