unknown cable tied to AC controls
dpetepiece
Post by dpetepiece »
I have a 2006 Vibe. Recently I removed the radio to replace the lights and found a control cable flopping loose behind the dash.
The cable connects to the rotary switch which determines where the ventilation system air is discharged, i.e. in my face, on my feet, on the windshield etc.
The other end of the cable appears to connect to the back side of the third button below the two AC buttons. The tabs are broken which would hold the cable in place into the backside of the third button.
Does anyone know what this cable does? Everything seems to be working.
Dave p
omega2551
Re: unknown cable tied to AC controls
Post by omega2551 »
I saw that in mine too, but didn't disconnect it. I assume it's just a place holder that they were too lazy to get rid of. I think in some models that spot is for the traction control feature on/off button.
Its a mechanical link that ties the air direction rotary switch to the recirc control. When connected, if you are in recirc mode and switch the air direction to defrost or half defrost the cable will trip the recirc button to turn recirc off. The idea is that defrost works better with fresh air than recirculated air.
dpetepiece
Thanks joatman
I would never have figured that out on my own.
dave p
jcjstern
Post by jcjstern »
The whole cable came out on me. Can someone PLEASE tell (or show) me where this end goes?
Welcome to GneVibe! What were you doing in there to notice it was disconnected?
jcjstern wrote:The whole cable came out on me. Can someone PLEASE tell (or show) me where this end goes?
It has to go on the back of the HVAC controls, probably behind the one that controls where the air comes out (vent/floor/defrost)
I'd take a picture of it on mine, but it's back in behind, and even if I just pull the radio to see back there, I might not be able to get a good picture. I'll look the next time I have the radio out, but hopefully some one else will post a pic before I can get around to it. It is something you can leave off with little to no effect, especially now that the weather should be getting warmer
I leave mine disconnected all the time. I almost never use recirc, and can remember to turn it off it I happened to have used recirc and later need a quicker defrost, don't need the car to do that automatically. I disconnected mine on the back of the recirc switch though.
jcjstern
Post by jcjstern »
Thanks much for your quick reply! Since leaving out doesn't affect the function of things, I'm good with that. Thanks again, I was seriously about to loose it! :D
jcjstern
Post by jcjstern »
Okay, so I'm all done worrying about the stupid cable and, BAM...I see it!
Never occurred to me to look here
joatmon wrote:It has to go on the back of the HVAC controls
. Yep, joatmon's right! I've included a picture incase anyone else encounters the same issue.
jcjstern
Post by jcjstern »
joatmon wrote:Welcome to GneVibe! What were you doing in there to notice it was disconnected?
Thanks! One of the bulbs behind the HVAC control panel went out. It drove me crazy, so I finally pulled everything to replace it. Seems it can never be a simple 1-2-3, so I'm glad you all are here. This has been the only place I've been able to consistently find answers to what I'm looking for!
Satisfying that when you ran into a problem that convinced you to finally stop being a lurker and join up that we were able to help
jcjstern wrote: I've included a picture incase anyone else encounters the same issue.
weasle05
Post by weasle05 »
any idea what the part is called? there are 2 tabs that broke off that keep the cable into place when i was updating to an aftermarket radio. hoping it isn't expensive to replace
SeattleJeremy
Post by SeattleJeremy »
weasle05 wrote:any idea what the part is called? there are 2 tabs that broke off that keep the cable into place when i was updating to an aftermarket radio. hoping it isn't expensive to replace
The tabs on mine are broken too, I'd love to fix that.
